Results 1 to 3 of 3
    Wizard of the Trail
    Reputation: Geist262's Avatar
    Chris king hubs with avid rotor
    Hey Guys, I have a question about rotors. I have a set of king hubs from 2002 that was on a 26 wheeled bike. I had them relaced to 29er wheels. I had hayes rotors bolted on and I plan on changing them to avids. Anyway, as I was unbolting the rotors, I found 12 spacers, 2 per bolt under the rotor. Do I need to use these washers/spacers or were they there to adjust for a misaligned caliper? Thanks.
    There is no charge for awesomeness......or attractiveness.
    Good rep does not wash out the bad, nor the bad the good.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Im no brake expert but I would remove the washers and hook everything up. If everything lines up then great. If its not alignable by your standard caliper adj, then consider using the washers.
    Sheepo
    Raised in a Chicken-Coop by Chickens
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    Usually you use spacers on the caliper to fine tune, not on the hub. I'd leave the spacers out of the rotor install. But, like Sheep, I'm no expert. Just some schmo on the interwebs... Take with a grain of salt.
    Amolan
