Results 1 to 3 of 3
    Chattering Elixir 5
    So all of a sudden my front brakes are chattering and are making what I can best describe as a grinding feel/noise. When I hold the front brake and compress the fork or "work" the wheel back and forth a bit it almost feels as if the pads are moving in the caliper. The wheel will rotate slightly in both directions with the brakes applied. Any thoughts?
    I have the same problem with my tektro disk. I sanded down my pads thinking it would be contaminated but that didn't solve it.
    P.s. I only get chatter when I get the pads up to temperature when they are cold they don't chatter do yours Pdlpwr?
    2011 Cannondale Trail SL3
    2012 Santa Cruz Tallboy DXC
    Did you check if any of the bolts are loose? (caliper and adapter)
