Results 1 to 11 of 11
    Aug 2013
    ChaserTech Disc Adapter (Help!)
    Hey there! I'm wondering if anyone knows anything about the chasertech disc brake adapter and the best way to modify it. I bought the 170mm kit and recently installed it, but ran into a problem where the bolt on the ball joint (the one that attaches to the plate that connects with the seat stay and dropout) is directly contacting the rotor! The only obvious fix I can think of is putting the ball joint on the outside of the plate instead of the inside...however this puts the whole adjuster bar at more of an angle and I'm guessing it may not be as structurally sound. Or maybe it is? Take a look at the pictures I provided, which show the problem and my possible fix. What do you guys think / advise?
    PS please note that the first two pictures are of my possible fix
    Attached Thumbnails Attached Thumbnails ChaserTech Disc Adapter (Help!)-img_20130825_143642_748-360x640-.jpg
    Birdman aka JMJ
    Reputation: Birdman's Avatar
    Two options I see.
    1. Mount the bolt on the other side of the adapter plate and call it a day. It should be fine.
    2. If you have digital calipers (even $12 Harbor Freight ones), remove the bolt that is interfering with the rotor and measure it carefully (shoulder diameter, thread size/pitch, etc.). It could be a fairly common shoulder screw. Go on the McMaster Carr website and find a matching shoulder screw with a lower head height that will clear the rotor.
    If it's a simple bolt that has a sleeve over it, again, match the bolt diameter & length and find one with a shorter head (hardware store will have 'em).
    Good luck.
    JMJ
    Aug 2013
    For option #1, I did think of that but the problem is that the ball doesn't have threads, and I'd have to throw a nut on the other side.
    Option two sounds like it would probably work, I'm checking out that website now and I think I can find the right size with a low head. I did contact ChaserTech and they recommended that I simply shave off 2mm from the bolt head, which is basically the same as your option #2.
    Thank you for the suggestions!! Should be straightforward from here
    B A N N E D
    Why would you need a nut on the otherside.
    Aug 2013
    Quote Originally Posted by cobba View Post
    Because the ball joint doesn't have threads, so there would be nothing to hold it to the bolt..
    B A N N E D
    Doesn't the bolt screw into the adapter.
    Birdman aka JMJ
    Scratching my head over that too - need a picture of the ball joint removed from the bracket.
    JMJ
    B A N N E D
    The first & second photos show it attached on the outside with the bolt screwed into the adapter so I don't know why or where a nut is needed for attaching it that way.
    Aug 2013
    The only threaded piece for the bolt to screw into is on the black plate that the ball joint connects to.
    Plays with tools
    Reputation: customfab's Avatar
    What's it look like when the skewer is actually tightened down?
    Aug 2010
    I think he thinks you mean thread the bolt from the outside with the ball joint on the inside of the adapter (not on the outside like in pics 1 and 2).
  1. Trek Disc-O adapter
    By Adam490 in forum Brake Time
    Last Post: 04-12-2012, 09:07 AM
  2. Replies: 0
    Last Post: 09-09-2011, 11:59 AM
  3. Who makes this Disc Adapter?
    By j306 in forum Brake Time
    Last Post: 05-09-2011, 02:20 PM
  4. Hayes disc brake adapter????
    By grantpro in forum Brake Time
    Last Post: 04-05-2011, 09:40 PM
  5. Hoo Koo E Koo rear disc adapter
    By Jeepdude in forum Gary Fisher
    Last Post: 03-14-2011, 07:02 PM
