Results 1 to 5 of 5
    Changing Rotors fom 185mm to 180mm
    I have Shimano Alivio brakes that have a 185mm front. Can I put a Hope 180mm rotor in its place?
    Never trust a fart
    Reputation: frdfandc's Avatar
    Are you sure they are 185mm? Shimano only sells 160/180/203mm rotors. Avid is the only company I'm aware of that uses 185mm rotors.
    But if it is a 185mm rotor, you can put a 180mm rotor, but have to either modify (file down) the caliper mounting bracket, or buy a new caliper mounting bracket.
    Can I put 183mm instead? It's only 2 darn mm. The Giant website says the front are 185mm, could they be wrong?
    I've use 180mm on my avid 185 setups with no problems
    rta
    rta is offline
    clarks makes a 185. Can order it through a J&B dist
    http://www.clarkscycles.com/index.ph...e-weight-rotor
