Results 1 to 3 of 3
    TC
    TC is offline
    Reputation: TC's Avatar
    changing pads on Juicy 3
    LBS gave me a set of replacement pads for juicy 5--said they'd fit.
    told me to use flat screw driver to force pistons back before I took old pads out.
    I did this, but new pads are really tight fit with no clearance for rotor. appears pistons are retacted, and don't want to snap them or something.
    any advice?
    TC
    TC is offline
    pushed a little harder with bigger screwdriver and ....
    put the pads in right side up (that ALWAYS works better...)
    last pads had worn down to metal-on-metal and the rotor now has some nasty grooves. some rubbing noise as I turn wheel on workstand (have not broken pads in on test ride yet)
    should I be worried about the "damaged rotor"? Will this work itself out? or cause premature wear on new pads?
    Or just cause a racket?
    Meh.
    Reputation: XSL_WiLL's Avatar
    As with cars, when the rotor has grooves worn in, they're usually trashed. I'd replace them.
    You may need to recenter your caliper to get rid of the rubbing.
