    Oct 2010
    Changing caliper seals from DOT to Mineral compatible
    Hiya,
    Relatively new to the disc world, but I am upgrading the brakes on my disc roadie.
    I'm changing the 2 piston calipers (TRP Dash) to Avid X0 Trail 4 potters.
    Why, ? Because I can and I like to muck around.
    As the Avids use DOT 5.1 and the TRP Parabox uses Mineral oil, I'm changing the caliper piston seals.
    I am chasing down a couple of leads to get suitable piston seals, but if they don't work out, can anyone recommend alternative suppliers ?
    The diameters in question are 14mm and 16mm
    Michael B
    Reputation: gmats's Avatar
    Apr 2005
    Good luck with that. Keep us posted.
    Oct 2010
    Some leads have come to nix, but pretty sure that I'll manage to do it !!
    Any help would be appreciated though
    Oct 2010
    Done it !!!!!!
    Conversion done and all good to a point.
    Brake fluid and brake pads don't mix .... :roll:
    The rears are fine, but the front still have a bit of contamination, but gradually clearing it up.
    Short flat ride last night, first one for 3 weeks, so may get out again tonight to do some more bedding in.
    So far so good, but took a bit of stuffing around with the bleeding to get it right.
    Hose routing is great, so looking pretty good so far.
    Went for a second ride last night, but this time with some hills. Got rid of some more contamination on the front pads, and they were much better, but in the end, I think there is still some contamination there. Picked up a set of sintered pads from the LBS (coz the resin ones were $7 more !! :?: ).
    Anyway, the end result is ...... BRILLIANT :mrgreen:
    The rear brakes work fantastic, and the front are 90%, but that's due to contamination. The modulation is great, as is the lever feel. Whilst it's early days, I am more than happy with it the end result.
    Phew 8)
  1. M775 Caliper compatible with M785 Brake Lever ?
    By Goran_injo in forum Brake Time
    Last Post: 09-24-2013, 05:24 AM
  2. Caliper piston seals?
    By bulerias in forum Brake Time
    Last Post: 01-28-2013, 02:15 PM
  3. Replies: 1
    Last Post: 08-09-2011, 09:44 AM
  4. Changing seals In RS Domain
    By OMNICELLL in forum Shocks and Suspension
    Last Post: 04-18-2011, 05:57 AM
  5. Shimano Deore XT brakes - leaking caliper seals
    By johna7770 in forum Brake Time
    Last Post: 03-09-2011, 08:26 PM
