Results 1 to 5 of 5
    Riiiiiide...
    Reputation: PsyCro's Avatar
    Centerlock lockrings
    Ive noticed new centerlock lockrings on the new stuff from shimano. No suprise coming from shimano. Can the old style lockrings still be used on the new hubs?? I just ordered a wheel with an SLX front hub and would like to use my old lockring because i have the tool for it.
    I think I need to Upgrade
    Reputation: AzSpeedfreek's Avatar
    Test fit it, if it fits you should be fine. Start with the rotor, does it fit on the hub? Does just the lockring fit by its self? If they both fit seperately, then try them together.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    depends to what hubs your refer too...for example on the 20mm front hubs, you should use the lockring that comes with the hub.
    Reputation: gticlay's Avatar
    The big red ones are just a new style BB tool so cheap and easy to get tool.
    Underweight Rider
    Reputation: AznRider's Avatar
    All shimano 20mm front hubs with CL uses BB tools(cept Pre 09 Saints).
