Results 1 to 6 of 6
    Nov 2006
    centerlock to 6bolt adaptor options?
    I've been running '07 mono mini pros with '07 xtr rotors (on 975 wheels) without issue. I'd like to build another wheelset and use my sweet hope rotors on this one. I really like the 975 hubs and I'm thinking about using them again on the new wheels and using an adaptor for the rotors. I see that formula makes one....I assume this is compatable with the standard 6 bolt pattern on the hopes...any hang-ups here? I can always use a 6 bolt hub I guess.
    Reputation: lama's Avatar
    Feb 2006
    DT Swiss makes nice ones also. I run some on my 240s centerlock hubs with Avid six bolt rotors no problems.
    I like the DT swiss adapters as well.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Dt Swiss are the nicest I think..
    then there is Shimano, Magura and problem solvers
    Meh.
    Reputation: XSL_WiLL's Avatar
    If they are Hope 2-piece rotors you may want to check the thickness of the carrier to make sure that it will fit on the adapter.
    Ricky Bobby
    Reputation: mville_mtnbiker's Avatar
    Aug 2005
