Results 1 to 8 of 8
    inner peace to make peace
    Reputation: TrailNut's Avatar
    New question here. carbon levers breaking?
    has your disk brake carbon lever broken broke, during a ride?
    ex. Formula Oro Puro, etc...
    Could I buy a replacement Oro Puro lever that's "fat" aluminum?
    “Everyday is a good day,” from the Blue Cliff Records, Yun-men (864-949 AD).
    Meh.
    Reputation: XSL_WiLL's Avatar
    Straitline makes a lever set for the Formulas. Is that what you mean by "fat?"
    I haven't had an issue with carbon levers breaking. Just keep the lever clamps slightly loose so that it can rotate in the event of a crash. Carbon is brittle and more likely to snap whereas aluminum usually bends. Though it's not like the carbon is going to give out when you grab a handful of brake.
    Single Speed Junkie
    Reputation: crux's Avatar
    Never had a lever break. One trick I use is to keep the Brakes loose enough on the bar so the will rotate in a crash, but tight enough that I do not accidently move them when grabbing for the brakes on a run.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    And you can get Formula alloy levers if you ever need to. Oro K18 levers, K24 levers, Bianco levers, they are all compatible...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Smile
    Quote Originally Posted by Dan Gerous
    Good. Thanks.
    Quote Originally Posted by TrailNut
    Good. Thanks.
    I hate carbon levers for brakes. I had two carbon levers break on Marta SL's. One broke in a crash which left it hanging like a wet noodle and the other lever had a crack near the bushing. Magura wanted $120 dollars for replacement carbon levers. A little steep for my wallet. I went with the aluminum levers at about 1/3 the price.
    Reputation: Dominator13's Avatar
    My Puro Lever broke in a crash in D-Ville. I now use Dangerboy's that are made for the Formula Oro's.
    "You don't stop playing because you get old, you get old because you stop playing!" - Unigeezer
    i'll install alloy levers
