Carbon Brake rotors
Printable View
  • 11-10-2012
    gotfish8
    Carbon Brake rotors
    check these out rotors out, I wonder if they reduce the "turkey worbble" noise? doesnt look like they have hit the market yet.
    Designed for a better ride. -
  • 11-10-2012
    Millfox
    They will probably have to go with special pads. Sintered would destroy the thing in one ride.
  • 11-10-2012
    shiggy
    Carbon fiber is a poor material for rotors.
    I have been using Avid BBDB/BB7s for 13 years with various rotors and still have not experienced "turkey gobble" or heard it from other riders' brakes.
  • 11-10-2012
    danielsilva
    WW will be all over these .... don't think i would touch them with a 10' pole though.
  • 11-10-2012
    Mr.Magura
    Naah Shiggy, that sure depends ;)
    I made a carbon rotor (and pads), using a composite intended for the purpose.
    That brake is anything but "poor".
    The thing is though, that the composites that are cheap enough for consumer applications, are pretty poor.
    If people were willing to pay for the right material, steel rotors would be a Wallyworld exclusive product.
    Magura :)
    EDIT: Pics of a "not so poor" composite brake.
  • 11-10-2012
    ridonkulus
    These might work considering they use carbon rotors on cars. I think they claim to cool better, but they turn a glowing red when hot, don't trust me on the cooling thing though. I don't know what type of pads they use.
  • 11-10-2012
    nvphatty
    CF rotors have been around in other arenas for yrs with steller success. It's application specific no doubt with 'heat' being the determining factor.
  • 11-10-2012
    gotfish8
    What is SiCCC?
    SiCCC, is a Silicon Carbide, Ceramic, and Carbon fiber braking material developed specifically for cycling. Our goal from the start was to create a more reliable, better wearing, lighter weight brake rotor. Silicon Carbide for friction, Ceramic for heat, and Carbon fiber for strength.
    The SiCCC disc rotor braking surface provides a level of power and progressive feel that equals or surpasses the best conventional rotors. The progressive power is excellent; not much lever effort is required, and the response is quick but not over-the-bar grabby by any means.
    The SiCCC disc rotor braking surface is a non-metallic composite and it is thermally inert, meaning it doesn’t expand and contract as all metal rotors do. There is no heat-induced stress distortion on the disc.
    This performance is available instantly: no warm-up needed.
    Hot or cold. Wet or dry.
    All of this and a serious weight reduction.
    This can translate into improved suspension performance due to less inertia and handling at speed by reducing gyroscopic effect. The average rider noticing this science at play is debated, the joy of a turkey-gobble free bike that is also lighter is undeniable.
    How it works:
    Braking, in this case, is turning kinetic energy into heat. Bicycle disc brakes operate on a transfer film principle. Pad material is transferred to the braking surface of the rotor (which is the reason for a bedding in period). This transfer results in both the friction and the lubrication to provide usable braking. The specific selection of materials determines the progression and wear of the rotor and pads.
    Speaking of wear:
    Currently, it is easy to chew through the highest priced rotors on the market in a season. SiCCC rotors? Well, let's just say we will be in the pad business because these rotors are just too tough. The longevity of the rotor braking surface is down right astounding.
    What are SiCCC rotors compatible with?
    Sintered metal, organic, semi metallic, kevlar, ceramic, resin and 'unidentified' oem pad materials were all tested. All major hydraulic brake systems, Dot 4, Dot 5, mineral oil as well as mechanical systems were tested.
    The two different options explained:
    The SiCCC material is expensive and it is challenging to work with. But for total weight reduction, no frills, no fasteners, just light and tough - a one piece rotor is the lightest we can make. That means it gets our soon to be coveted -SFL- designation. You will instantly know what that acronym stands for when you pick up a product bearing that trademark. Some of us will tolerate an extra gram or ten for a color keyed component or to save a buck. The carbon spider on the two piece rotor reduces manufacturing cost. The rivets add some weight, paint adds some too. A color matched spider on your favorite carbon bike? Yes, please. We know it's a hard choice. That's why we offered both, we couldn't bear to leave one on the shelf.
    One more thing on colors, get us some feedback!:
    Turner orange, Ibis silver, Santa Cruz yellow, Yeti teal? Why don't you tab on over to Facebook and like us, then tag a picture of the bike you are going to bolt up these SiCCC rotors to. If you sign up for the 2 piece, we will collect your color choice when the options are photographed, post project funding.
    Other things to note:
    Like all rotors, it is important to bed in the pads+ rotors. At least a few laps around the block in a controlled environment to accurately follow the bed in procedure in the video on our site and written instructions. New brakes, pads or drip something on the rotor? Remove, clean the rotor with acetone and start the bed-in over. Also, 200mm will come later in two piece and SFL. SFL first. There are no plans for two piece 140mm because of manufacturing efficiencies.
  • 11-10-2012
    nvphatty
    CF pads as well hence requiring heat for effectiveness.
  • 11-10-2012
    gotfish8
    It the same technology as these Brembo Brakes - Carbon ceramic discs
    I would try them, I think innovation is awesome!
  • 11-10-2012
    Mr.Magura
    No. That is an old wives tale.
    Magura :)
  • 11-10-2012
    nvphatty
    Magura :)
    which part the heat or CF pads?? dunno bout the wives but wise tale yes.;)
  • 11-10-2012
    Mr.Magura
    This is due to the way IR radiation works. The higher the temp, the higher radiation.
    The is a log. function, so like 10C higher rotor temp, gives like 30% higher radiation, once you're up around 120C you really feel the difference. The rotors will be able to dissipate a huge amount of energy.
    Magura :)
  • 11-10-2012
    Mr.Magura
    The requirement of heat to work proper.
    Mine are brutal when cold.
    As I recall, the effect increases like 10-20% from cold to ideal temp.
    Ideal working temp is reached pretty quick though, when keeping the mass low, not that it makes a noticeable difference in a bike brake.
    Magura :)
  • 11-10-2012
    nvphatty
    Magura :)
    ahhhhhh i see and frankly makes sense with constant R/D over the yrs. My experience comes from MC racing when they used shrouds to help them get up to operating temp and retain it.
  • 11-10-2012
    Mr.Magura
    That would be like 15 years ago, no?
    Back when the rotors were massive, and vibrated like they were paid to do so.
    Magura :)
  • 11-10-2012
    nvphatty
    Magura :)
    yes roughly. now days the MOTOGP bikes have much smaller/thinner rotors that work straight away however any sign of wet and iron rotors get put into action.
  • 11-10-2012
    shiggy
    The automotive race rotors are carbon/carbon, not carbon fiber, and need to be near red hot to be effective.
  • 11-10-2012
    Mr.Magura
    Ok, so I am chatting with somebody to whom it wasn't an old wives tale, but real experience, just long ago :thumbsup:
    I have noticed the performance going down in the wet, but on a bike, there is still plenty of excess brake power from the composite brake I have.
    The only thing I can come up with, that is not so nice, is the transition from wet to dry.
    It can be pretty brutal if I don't pay attention. It is just a matter of habit though. Once you are used to this, you pay more attention to conditions that may cause a rapid transition.
    On a MOTOGP bike though, I would probably miss a heartbeat or two, if surprised by such a transition :D
    Magura :)
  • 11-10-2012
    Mr.Magura
    Look a couple of posts above, and such a type of rotor material, would be what you see ;)
    It's been a while since that was sorted out.
    Magura :)
  • 11-10-2012
    ehigh
    It's all conjecture till I try it. Maybe one day.
  • 11-10-2012
    Mr.Magura
    LOL! :D
    Drop by and have a go.
    Magura :)
  • 11-10-2012
    ehigh
    Are you in the United States?
  • 11-10-2012
    Mr.Magura
    No, Denmark.
    Drop by though. The weather sucks, but the food is fair ;)
    Magura :)
  • 11-10-2012
    danielsilva
    No, Denmark.
    And the ladies are pretty damn fine :thumbsup:
  • 11-10-2012
    Mr.Magura
    I hate to disappoint you, but that's an old wives tale :D
    Look further south in Europe my friend.
    Magura :)
  • 11-10-2012
    danielsilva
    I am from southern europe :D It is just a case of "the grass is always greener on the other side of the fence" :thumbsup:
  • 11-10-2012
    Mr.Magura
    On a different note.
    I just had a chat with one of the guys behind these brakes.
    They are definitely on to something.
    The way they make them, is close to the brake I made, but with a fraction of the cost.
    Looking forward to see where this leads.
    Magura :)
  • 11-10-2012
    danielsilva
    They have a kickstarter page up, SiCCC Bicycle Brake Rotor: Silicon Carbide-Ceramic-Carbon by Kettle Cycles — Kickstarter although not yet active. At the price ( at least in this stage ) of $165 i might be on the backers list tbh.
  • 11-10-2012
    RustyIron
    Could this thread be spam, intended to garner donations to line someone's pockets?
    Make no mistake, there are NO carbon fiber rotors offered for sale by this company. Right now, it's just a figment of the imagination of some wannabe.
    I checked the location for "the company," and it appears to be an apartment or a townhome in Illinois. I'll not divulge the exact location out of respect for privacy. Mister GotFish, you're also from Illinois. Are you, or do you know the people behind these so called carbon fiber rotors?
    What's telling is that this "company" doesn't really sell a product, but they are begging for money. They are begging for $15,000 in donations for this project. But their web page admits that this is not a "live project," it is only a "draft." If I donate $100, what will happen to it?
    If this company actually had a legitimate product, plenty of venture capitalists would be lining up to invest. I try to be openminded. If you send me a sample of your product, I'll evaluate it. If i find it to be a worthy product, perhaps we can talk about an investment in the company. I'll need four six bolt rotors, two 203 mm and two 160 mm. I'll give you an honest evaluation. Send three more 160's, two 203's, and a 185, and I'll do a better evaluation for you. PM me for the shipping address.
    The company's web page lists a bunch of "authorized dealers" across the country. I followed the links, and NONE of these authorized dealers actually exists. None.
    As far as I can tell, the company sells nothing, but they will gleefully accept donations, nothing more.
  • 11-11-2012
    Mr.Magura
    Did you actually read what Kickstarter is about?
    It's not donations, but a number of confirmed sales to get a new company off the ground.
    Now captain Obvious, can you figure how to add up, that they are on Kickstarter, for getting their FIRST production series off the ground, and that they have not run the FIRST series yet, thus only have prototypes, which are not for sale.
    It's funny that you choose the first real innovative product in a long time, for your paranoid post, and not one of all the semi-fraud products we have seen lately.
    I especially like your logic: if they won't give you their product for free, they don't have nothing :D
    If I were in their place, you'd be the last person I'd consider as product tester.
    Magura :)
  • 11-11-2012
    RustyIron
    I stand corrected. That guy runs a great company that makes a wonderful product and consumers are beating down the door of his apartment to get their hands on these rotors and "kickstarter" is a great business plan used by many successful companies that employ thousands of people.
    :rolleyes:
  • 11-11-2012
    Bataivah
    Have to start somewhere I guess. Every WW in the world will have a set of these. I'm no WW but I
    love to shave grams when I can, and rotors were something I've been waiting to become lighter
    one day.
  • 11-11-2012
    nvphatty
    Originally Posted by Bataivah View Post
    Have to start somewhere I guess. Every WW in the world will have a set of these. I'm no WW but I love to shave grams when I can, and rotors were something I've been waiting to become lighter one day.
    If not these it'll be something else down the road...who knows CF uni/dual crown forks W/hollow Ti QR axles or CF suss linkages. but rest assure it will always be something.
  • 11-11-2012
    B.BL
    :rolleyes:
    Kickstarter is a service that allows startups to sell a batch of prototypes, without worrying about leftover stock. A colleague of mine currently makes and sells some electronic device over that platform.
  • 11-11-2012
    danielsilva
    :rolleyes:
    Actually thousands of profitable and known businesses started on Kickstarter and some of their projects reach the multi-million mark. Last years they reached the 100 million dollar mark in funding ... so yes there are thousand of successful projects/companies that started on Kickstarter.
  • 11-12-2012
    mazspeed
    I am very very interested in these. Will pick them up tomorrow if they fit the hope v4 setup at the 203-180 sizes. They sound cool, and the price is low enough to mess around with them.
  • 11-12-2012
    Cotharyus
    I must say, personally, I find this idea quite interesting. Quite.
  • 11-12-2012
    SpecialWarr
    So what is the curing/ treatment/ preparation processes are you using? No need to be too revealing...just curious!
  • 11-12-2012
    Mr.Magura
    If you're asking about my brake, I have to say that I can't tell you (well, I also won't) due to my confidentiality with my supplier.
    If you ask about the brakes from the company in Illinois, I can tell they won't tell, cause I've already asked when I talked to them a couple of days ago ;)
    Magura :)
  • 11-12-2012
    SpecialWarr
    I was thinking about yours, but I can't say I expected a detailed lay-up or anything.... I understand the confidentiality agreement argument....I don't want to get anyone in trouble, I was just curious.
  • 11-12-2012
    Mr.Magura
    Pretty much the latest and greatest in composite friction materials, is the Carbenix 4000.
    I would think you could find some info about that online.
    Mine and theirs, are pretty close, since we are talking SIC composite.
    Magura :)
  • 11-12-2012
    410sprint
    Carbon fiber or composite rotors? Sounds like an expensive solution to a problem that largely doesn't exist.
  • 11-12-2012
    Mr.Magura
    That depends how you define the word "problem" ;)
    A lighter rotor, that is very hard wearing, and immune to fading.
    That seems pretty nice to me.
    I am at least very happy with mine.
    Magura :)
  • 11-12-2012
    drbelleville
    Just to chime in, I am not sure what happened to them, yet Fibre-Lyte of the UK offered carbon brake discs around 2008. Maybe some of our UK friends might be able to shed some light on these. I do not know if they were for show or not. What I do know is that I do not see them on their catalog anymore.
  • 11-12-2012
    mazspeed
    Magura :)
    You have a set? Pictures. :)
  • 11-12-2012
    Stumpjumpy
    No reason carbon-ceramic brakes would not work on a bike, but they would likely be crazy expensive if done properly. Production cars from Ferrari, Porsche, etc. have offerred CF rotors for over a decade, now. Replacement cost is about 5 grand PER WHEEL.
  • 11-12-2012
    distro
    These aren't carbon ceramic, that is a totally different beast. Interesting concept these brakes are, wonder how well they compare to their metal counterparts.
  • 11-12-2012
    ehigh
    Magura :)
    Hey man, when I was in Santa Cruz I met two Danish girls from Aarhus who were hitch-hiking through the state. When they looked at my bikes in the back, she said, "oooh you're must be into downhill" with a cute smile and wide eyes and all her Danish accent.
    What are the odds?
    (so you're saying when I try your brakes you won't have fine Danish women serving our end of the day dinner?)
    I took out the eye roll emoticon from your statement and now it reads much more truthfully. Sorry man, but your sarcasm isn't carrying you too far here. Try being a little bit more optimistic. You aren't saving anyone from anything by being so scathing, especially yourself.
  • 11-12-2012
    WarBoom
    This is very interesting
    Even if they werent so light just the heat dissipation characteristics would be worth it
  • 11-13-2012
    RustyIron
    Thanks, Fanboy, I don't need the support of you or your cadre of little friends.
    I shined the light of truth on this "Phantom Rotor" manufacturer. He runs his "business" out of his apartment, none of his claimed "authorized dealers" actually exist, he has no product to sell, and he's looking for donations.
    Are you really his BFF, or are you just talk? How much money have YOU donated to his cause?
    There is one cold, hard fact of which you seem to be unaware. There are two kinds of people in this world: the talkers and the doers. The "Big Talkers" are a dime a dozen, and they're all just one year away or one more cash infusion away from "making the bigtime."
    To show that I'm not a complete cold-hearted cynic, I will humbly retract my comments as soon as he starts shipping a real product, let's say just a hundred units that last on consumers' bikes for more than 6 months or 600 miles. Is that a fair test? To be honest, I'm not going to hold my breath waiting. But if the day ever comes when you write a review for the "Phantom Rotors," I'll be one of the first ones to read it. Until that day, be well.
  • 11-13-2012
    ehigh
    Man lighten up. All you're doing is leaving scathing remarks, and for what? It's hard to get business like this rolling. Go for it and shoot him down. I understand that you wouldn't invest in it. Neither have I. But how do you expect industry innovation when there is such tight competition?
  • 11-13-2012
    Mr.Magura
    They are exactly carbon ceramic ;)
    And no, I'm not guessing here, that's knowledge.
    Magura :)
  • 11-13-2012
    nvphatty
    Magura :)
    would you kindly send some Fedex overnight i could use it..:p
  • 11-13-2012
    Mr.Magura
    I have a carbon ceramic brake yes, but it is one I made like a year ago.
    Look further back in this thread for a couple of pics. There is a thread about it somewhere as well, with more pics and some thermographic images.
    Mine is though a bit different, and the cost was a wee bit high for most peoples taste. As I recall, the material cost of the rotor and a set of pads, was like 3,000$.
    Magura :)
  • 11-13-2012
    Mr.Magura
    Back when I made mine, I didn't do much for the sake of saving weight, as my aim was to get more power, and to eliminate fading.
    As I recall, mine ended up around 95g for a 203mm rotor.
    Magura :)
  • 11-13-2012
    Mr.Magura
    What are the odds?
    LOL! Well, the odds are not good for that to happen twice ;)
    Fine Danish women are few and far between, They do exist though. I have one, and I know another guy who also has one :D
    Regarding RustyIron, just ignore him. He has no clue what he is talking about, and obviously forgot to take his pills.
    Magura :)
  • 11-13-2012
    Mr.Magura
    Naah, I just made one for myself for fun.
    If the Illinois company get this off the ground, they will also bring this into a completely different price bracket.
    They expect to sell rotors for like 100$, mine cost like 3000$ for the material alone (rotor and pads).
    Magura :)
  • 11-13-2012
    nvphatty
    Magura :)
    I was referring to the knowledge.....2nd thought
  • 11-13-2012
    Mr.Magura
    LOL!
    I'm still a bit slow, only on my second cup of coffee this morning.
    Magura :)
  • 11-13-2012
    nvphatty
    LOL!
    Magura :)
    just home from work and bedtime for me...zzzzzzzzzzzzzz
  • 11-13-2012
    Mr.Magura
    As I recall, they never got it off the ground.
    Back then I believe the reason was the cost, as they tried to do it the same way as Honeywell (and yours truly did).
    As I recall, it worked well though.
    Magura :)
  • 11-15-2012
    distro
    Magura :)
    They use carbon, and ceramic materials.. But are not made the same as carbon ceramic road discs. Those are made with loose not wolven carbon fiber form what I have seen. Just was trying to point out this is a different process..
  • 11-16-2012
    Mr.Magura
    You can have carbon ceramic (CSIC) in just about any form.
    I have so far seen random fiber, UD, something in between the two, Textreme style , and so forth.
    In my experience, the big difference is rather the SIC component, than the layup schedule of the carbon.
    Magura :)
  • 11-16-2012
    jos3ph4ever
    Backed one set of this Siccc rotor,hope it would be nicer than my hope floating disc and twice as light.
    Cant wait to get it now,but still have to wait until 2013 JAN.:):)
  • 11-17-2012
    AaGro
    Magura
    You seem to have had a few chats with the people working on this. Any chance you might get them to chime in here? I for one think this idea has a lot of merit and would be interested in hearing about compatibility across braking platforms, and their strategy for pads.
    thanks,
    AaRon
    BTW -to the grouchy guy: starting a business in your apartment or garage and driving it to the revenue generating stage is not a negative thing, it is hugely positive and the longer you stay small and lean, the better. Think abouth the google garage - a rented garage (not even the house) in Menlo Park.
  • 11-17-2012
    mazspeed
    Not only is not a negative thing, it's how most people start businesses. The guy is obviously completly clueless, and was not worth debating. Never argue with an idiot, they drag you down to their level and beat you with experience. :)
  • 11-17-2012
    Mr.Magura
    If they are anything near the one I made, which I am fairly sure they are, you can look forward to improvement pretty much in any aspect.
    I run mine in a Hope M4, which seems to work rather well.
    I will though move it over to try in on my Zee.
    Magura :)
  • 11-17-2012
    Mr.Magura
    Magura
    thanks,
    AaRon
    The guy I have been chatting a bit with, already reads this topic.
    To be honest, I would also think twice before joining this topic as the manufacturer.
    All the hear-say and religion this is up against, makes for a bumpy ride at best.
    Add to that all the self proclaimed experts on composite friction materials (hey they most likely saw F1 on tv). ;)
    Just look at the thread I posted about my brake, and I don't even sell anything :D
    Magura :)
  • 11-17-2012
    Bataivah
    I'll be happy to buy something made in USA for a change. At least until it gets outsourced
    and a price drop.
  • 11-17-2012
    jos3ph4ever
    Magura :)
    I will run mine with hope tech x2 that currently run with hope floating rotor that loosen for the rear disc after 4months use only..
    With this SiCCC material i think they will perform better than floating disc even they are made into one piece,is it Mr.Magura?
    Does ur rotor bend during long decents?
  • 11-17-2012
    Mr.Magura
    Yes they will probably perform better than a floating Hope rotor. I would sure expect so.
    Let's see. Now they have plenty of backers, so there is going to be a pretty hefty production. I look forward to see what they made of it.
    My rotor is as straight as it was when made. That's the way it will stay ;)
    Mine will survive 400C permanently, with no ill effects.
    As I understand the process they are using, those rotors should have approx. the same properties regarding warping and oxidation.
    Magura :)
  • 11-17-2012
    jos3ph4ever
    Magura :)
    Great to hear that from you.
    The project already funded,just wait the date end and they will start making them,luckily i backed earlier if not many of them already sold out.
    400c is very hot,i dont think bike brakes can create that heat to spoiled it right?
    What inpired you to make this rotor by yourself?$3000 is expensive but it is unique i know.
  • 11-17-2012
    Katz
    I backed them for a pair of two-piece rotors with color choice. I'm a casual rider so extra 10 grams won't bother me :)
  • 11-17-2012
    Mr.Magura
    It will be hard to maintain 400C on a bike, even on the front.
    The short answer: because I could ;)
    I have made composite brakes for performance cars in the past, so it seemed natural to make one for a bike as well.
    Yes that is a fair pile of dough, but the first of something will always turn expensive.
    The composite brakes I made for cars, were like 20,000$ for a pair for the front end, so relatively speaking, 3,000$ is not too bad, especially for a single piece run.
    Keep in mind that this is raw material cost, thus not really commercially interesting.
    Magura :)
  • 11-17-2012
    mazspeed
    I'm going to back them as well shortly. I was waiting like a knucklehead for others to do it first :)
  • 11-17-2012
    Bataivah
    Well, if I had an extra $150 I would get in on it.
  • 11-18-2012
    lml427
  • 11-19-2012
    dubthang
    I got in on this early. I think I was the 5th or 6th backer for a set of 160mm SFL's. I'm excited to see how these come out, and I'll do a full write up on them when they arrive.
  • 11-19-2012
    doccoraje
    Great comunication from Kettle.
    I couldn't find any reference to thickness of their rotors either on their site or posts in here, so I asked them, I got response in less than an hour.
    Just in case someone had the same question, 1.9 mm I was told by Aaron.
  • 11-20-2012
    ruscle
    Very interested in this, but I run Hope V2 brakes with 183mm rotors. The V2's require a slightly larger track surface for the calliper to clamp onto. The 2 piece rotor looks like it has a deeper track but they are only making them in 180mm sizes, but I imagine the extra 3mm won't make much difference.
  • 11-20-2012
    mazspeed
    Not true, only issue would be the 2 piece. I have run the V2 and now the V4 and they all run the same rotors as the rest. It should work, given they work for all other normal rotors as well. Only the vented won't work.
  • 11-20-2012
    PSICODROMO
    but the carbon rotors only brake at very high temperature
  • 11-20-2012
    wallstreet
    Is it really necessary?
    Do top mtb'ers have this kit? Often the answer is no :)
  • 11-20-2012
    Mr.Magura
    May I recommend you do a bit of research before throwing out claims?
    The above claim is as far from the facts as possible.
    I happen to have worked with designing composite friction systems, and have even made a composite brake for my bike. My experience, and just about any substantiated fact you can find, says pretty much the opposite.
    One thing I often wonder, is why people find it a must, to claim knowledge, about things they have no idea about?
    Magura :)
  • 11-20-2012
    Mr.Magura
    Top mtb'ers don't have this sort of technology yet, as so far the only person or company, I know of that have been willing to spend the amount of cash it takes, till these guys came along, has been me.
    Magura :)
  • 11-20-2012
    wallstreet
    It will be interesting if weight is reduced & benefits of stopping power & low heat - from what you posted earlier sounds a future... If the price is right for the masses, I doubt it for now... I can see DH & Enduro riders probably utilizing its stopping power. Like another topic I read it's not going to add seconds of value in a straightforward measure yet. Unless weight is significant. Interesting anyway.
    Ridley came out with new hidden integrated brakes on their top range race road cycles and thus futurism is what I enjoy.
  • 11-20-2012
    natrat
    so i guess they don't warp so no need to true? I would like to try out a 180 just because it looks so friggin cool
  • 11-20-2012
    Mr.Magura
    I'd say 100$ is pretty much a reasonable price, at least low enough to bring it down in the range that most would be able to consider.
    The real interesting benefit, besides low weight and more power, is very low static friction.
    That sure offers a benefit you can see on the stop watch, as it allows you to brake harder, with much higher threshold for the wheel to lock up.
    As I mentioned earlier, I sure like mine, and this would be one of the real nice features, that I have gotten used to enjoy, and would be a benefit in a race situation as well.
    Magura :)
  • 11-20-2012
    Mr.Magura
    To true ceramics????
    That sounds like a very bad idea :D
    Magura :)
  • 11-20-2012
    AaGro
    @ $70 for the two piece it is less than buying replacement rotors for my Formulas. I think I am most interested in long term durability which is (at least in theory) one of the big advantages of this set-up. Second place for me is overheating of break rotors - rare for me as a recreational rider but it does happen. The weight change is nice, but to tell the truth I'd rather have the 2-piece than the SFL - I just think they look cool as hell. And as of yet outside of my experience is the very low stiction point of this material - there are a lot of potential benefits to this if the learning curve isn't too steep, and if the stiction point isn't so low that you can't lock-up a wheel when you want/need to..
  • 11-20-2012
    wallstreet
    @aAgaro
    It's a very interesting read as I just finished reading about it! 40g wow, very interesting. Affordable too. Curious to hear test trails come on MTB mags & bikeradar ;)
  • 11-20-2012
    Mr.Magura
    @ And as of yet outside of my experience is the very low stiction point of this material - there are a lot of potential benefits to this if the learning curve isn't too steep, and if the stiction point isn't so low that you can't lock-up a wheel when you want/need to..
    Mine has no problem locking up the wheel, if I want to, there is just much less risk of locking up the wheel, when breaking hard.
    I would expect those brakes are working more or less the same way.
    Keep in mind that you actually have more power, so the situation where I have seen the benefit, is when breaking hard, with uneven grip. Usually you'd have to brake less hard, to avoid locking up the wheel, when braking under such conditions.
    Also once you learn to control it, you will find that if the wheel stops rolling when braking across a rut or the like, the wheel will start rolling again once traction is restored.
    This takes some getting used to, as normal response to such an incident, is to ease off on the lever quite a bit, to get the wheel rolling.
    For a racer, this could very well save a significant amount of time.
    I am no racer however, but I like that it saves me a nasty situation from time to time, and brings confidence to breaking harder than usual.
    Magura :)
  • 11-25-2012
    ruscle
    V2 compatibility with 2 piece rotors
    I emailed them about the compatibility with the 2 piece rotor and the V2 calliper's and Aaron said it will all fit fine and there isn't an issue. The rivet on the 2 piece does look very small and quite far into the actual structure of the rotor, so should prove not to clash with the calliper of the V2. I think I will be backing them for a pair of 180mm 2 piece rotors. :thumbsup:
    Quite excited now and will be saving over 200g in weight. Main thing is gaining more modulation and power (Like I need that with Hope V2's!!) :D
  • 11-25-2012
    Wasmachineman NL
    Mr.Magura, Your like the Bob Page of brakes, I LOVE your modded brakes and other stuff, DIY all the way indeed!
  • 11-25-2012
    Mr.Magura
    Thanks a lot. :thumbsup:
    Now could you please enlighten me, Who is Bob Page?
    A Google search revealed the choice between a science fiction character, a sports caster, and a blues musician.
    Magura :)
  • 11-27-2012
    Wasmachineman NL
    Magura :)
    Bob Page is the leader of Majestic 12 in Deus Ex, He was also a major power behind nano-tech/augmentation in that game, Read the DX Wiki page about him: Bob Page - Deus Ex Wiki
  • 11-27-2012
    Mr.Magura
    So now I just have to take over the world, using brakes as a step stone....
    Intriguing thought :D
    Magura :)
  • 11-27-2012
    StanleyJ
    I don't have the moolah to get these... though I'm curious how well these SiCCC rotors will perform on a fully loaded MTB tandem. :D
  • 11-27-2012
    J:
    Just lay off the afterburners : D
    Ps, I need jet brakes on my bicycle too
