Page 14 of 14 FirstFirst ... 41011121314
Results 651 to 681 of 681
  1. #651
    Reputation: 006_007's Avatar
    mmmm bacon
  2. #652
    Reputation: CarlS's Avatar
    SO WTF happened to these guys? I just got a msg on FB that Kettle cycles has changed their name to SIC rotors. Are these guys really still in business?!? No one tried to sue them? I mean, really?
    https://www.facebook.com/SICrotors/?fref=ts
  3. #653
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Dunno, but I saw a fast guy at our race on Saturday with the carbon rotors. I have to wonder how they work here in the frigid North. Maybe not as bad in the winter as down South?
  4. #654
    Reputation: TracksFromHell's Avatar
    Jul 2014
    There are these things called steel rotors. They work amazingly well. They cost very little. They are amazingly durable. And the companies that produce them are 100000% better at customer service than a sick, unreliable, customer unfriendly, noncommunicative, lying, and over hyped, one person show that ignores all their customers and then waits for all the massive and widespread disgruntlement to die down before each yearly "relaunch" of the same failed product. You might be familiar with such a company from your own experiences.
    Better to be healthy than 'sick'. Pun intended.
  5. #655
    Reputation: Flamingtaco's Avatar
    Mar 2012
    But, but.... 3.5 ounces!!! That's like... 500Lbs of rotational weight!!!
    If it works on high-tech race cars, it can only be an improvement. Next up: Pads made of steel, rotors made of sintered copper.
    I will suffer no butt-hurt fools!
  6. #656
    Reputation: alexbn921's Avatar
    I was one of the first backers and received both the first gen and 2nd gen C rotors. The c rotors were better but lacked any real stopping power. I also was one of the first to get the pads, and oh man did that help. Real 1 finger power and the modulation was worlds better than any brake I have ever used.
    Full XTR with 180mm. resin pads rear. c pads front. I miss this setup as it was best I've ever had. The static friction on Sic rotors is truly a game changer at the limits of traction. That's the reason aircraft and the military use it. I never faded them and braking power as consistent regardless of temperature. I ride crazy steep stuff so I'm hard on brakes.
    Idea was great. Performance promise was living up to the hype with the new pads.
    Now the bad:
    Warped out of the box with no way to true them. What's the point of brakes that constantly rub.
    Constant frustration with the owners who were over there head and lashed out at any criticism.
    In the end I reluctantly took them off because of the constant rubbing and the lack of support from the company.
    They need to do right by us if they ever hope to make it as a company.
    FYI I wouldn't cook on them as there is probably toxic material going into your food.
  7. #657
    Jul 2014
    This was an interesting comment just saw on their Facebook.
    " Figured out why they went bankrupt today. First ride on the rear two piece. After a 2000 ft downhill three of the screws that hold the rotor to the center piece were gone. Middle of nowhere, so had to limp out. Next downhill, hit the rear brakes and the carbon rotor ripped from the center piece. I was really trying to be front brake heavy, I mean heavy. Total crap."
    That would indeed be a bad situation. And it could happen for sure with the Sic material.
    The scary thing is that fatigue is hard to spot in composites until it is too late.
  8. #658
    Dec 2008
    Interesting that they don't seem to have any contact details on their new website
  9. #659
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Quote Originally Posted by ctguru View Post
    If they did, I'm guessing they would be drowned in mails and complains from previous users.
  10. #660
    Dec 2008
    Quote Originally Posted by Aglo View Post
    That's what I was thinking
  11. #661
    B A N N E D
    info@sic-rotors.com
    Just put '@sic-rotors.com' into google, the page with that email address isn't valid anymore but you'll get a result that has it, you can see the page as a google cached page.
  12. #662
    Dec 2008
    Quote Originally Posted by cobba View Post
    info@sic-rotors.com
    I'll email them to see if they have a product that actually works!
  13. #663
    Jul 2014
    And what response did you get?
  14. #664
    Dec 2008
    Quote Originally Posted by TracksFromHell View Post
    Forgot, I'll email them now
  15. #665
    Dec 2008
    This is a copy of the email I sent them
    Just wondering if the product has been refined so it actually works comparable to metal rotors?
    I have a couple of sets of the C-processed 180mm and I thought they were good and used them for a couple of years. But when I went back to metal the difference was amazing. Carbons stopping ability is severely lacking compared to metal rotors
    Are there any new reviews of the product? I would suggest previous users of your product have been burnt and would be reluctant to try them again
    cheers
    REPLY
    Hello,
    The pads exceed ISO 4210 and we have posted the results here: ISO 4210
    Mating pad and rotor is an important factor.
    Thank you for your interest
  16. #666
    Reputation: phlegm's Avatar
    Can you pass along the URL they sent you? I can't seem to find the ISO piece on their site, although I am lazy and didn't look that hard.
  17. #667
    Dec 2008
  18. #668
    Dec 2008
    I also asked have they solved the warping problem in my follow up email
  19. #669
    Oct 2010
    Smile
    That report that they provided does not really mean/prove anything unless you can compare it to a comparable system (i.e. same size steel rotors and resin/metal pads).
    It just shows they passed a test, not how well it passed or how it compares with others.
    I'll still be holding on to my money for the moment, as I presume will other smart people
  20. #670
    Dec 2008
    Quote Originally Posted by MichaelB View Post
    Definitely not going to drop any more coin on his product unless they do an independent review compared to metal
  21. #671
    Thanks, but this actually proves nothing.
  22. #672
    Dec 2008
    reply regarding warping:
    I believe you are referring to the original start up issues during scale up.
    The brand is now owned by the same group as the chemical manufacturers.
    All processing is with in accordance to processing guidelines.
    So they are avoiding the questions, here is my reply:
    that doesn't answer the question
    the problem you have is previous customer experience
    you need to get your product out to individual reviewers for product testing
    there are pages and pages on the internet about how poor the original product was
    maybe flick some free samples to MTBAction magazine and a like for review
    if I order a set and they warp, will I get my money back?
  23. #673
    Jul 2014
    Definitely not going to drop any more coin, regardless.
  24. #674
    Are they owned by someone outside the US at this point? The responses seem like borderline gibberish.
  25. #675
    Dec 2008
    Quote Originally Posted by phlegm View Post
  26. #676
    Dec 2008
    This is there reply
    Hello,
    Thank you for your feedback. Our products are warrantied for manufacture defect.
    Best regards.
    Still haven't answered the questions
  27. #677
    Reply back with a link to this thread. If they care, they will respond. If not, then you know what to do with your money.
  28. #678
    Dec 2008
    Quote Originally Posted by the-one1 View Post
    I'm happy with my metal rotors at the moment. I'm happy to use them if they give me a set to try
  29. #679
    Dec 2008
    Whatever you do, don't buy these rotors.
  30. #680
    Dec 2008
    Quote Originally Posted by Crossmaxx View Post
    I've all ready got 2 sets
  31. #681
    Reputation: las-palmas's Avatar
    Many of us have these rotors.
    They do not function better than the cheepest of V-brakes did 30 years ago.
    Some have claimed that they have these rotors functioning well, I wanted them to function. They did not for me.
    Good looking rotors is not what should replace a functioning brake system.
    errare humanum est
