    cantilever vs v brake bosses
    Is there a difference, are cantilevers and v-brakes interchangable or does the positioning of the brake boss indicate if one or the other can be used.
    they're the same afaik.
    More or less what he said, the brake boss positioning for normal cantilever a V-Brakes is the same, but cable pull lengths are different so you need either the correct brake levers or an adapter like a Travel Agent to correct for the longer cable pull on a V-brake. If your bike has cam operated brakes or hydraulic rim brakes then all bets are off because they do have the bosses in different positions.
    As a further aside, if you want more power than cantis but also want to keep your old levers you can do like the cyclocross guys and use mini-v brakes which have the same cable pull as cantilever brakes.
    2009 Redline Conquest Pro, 2008 Trek Fuel Ex8
    2007 Kona Cinder Cone utility bike
    Yes I spent too much on bikes.
    ballbuster
    Reputation: pimpbot's Avatar
    Yep.. third that
    Quote Originally Posted by mapleridge03 View Post
    V-Brakes and Canti brakes use the same bosses. The only rub is where to hang the brake cable with canti brakes since V-Brakes don't need a center hangar. On rear brakes of my cyclocross bike, I use an anchor attached to my seatpost clamp. I've seen other guys use a bolt on the stem for the front canti brake, but that only works with rigid forks.
    Canti brakes rule! Don'tr change them... except for disc brakes!!
  1. V-brake or Cantilever?
    By tw3nty9er in forum Beginner's Corner
    Last Post: 07-16-2010, 12:29 PM
  2. A cantilever brake question.
    By henrymiller in forum Vintage, Retro, Classic
    Last Post: 05-30-2010, 12:31 PM
  3. Cantilever to V-brake
    By jroymcd in forum Brake Time
    Last Post: 12-28-2008, 01:39 PM
  4. Clamp on Cantilever Brake Bosses
    By Dawg in forum Vintage, Retro, Classic
    Last Post: 08-26-2007, 09:54 AM
  5. How can I tell if it's V-brake or cantilever bosses on a frame?
    By indigosky in forum General Discussion
    Last Post: 09-23-2004, 08:13 PM
