    Nov 2007
    can you use the same bleed kit for mineral oil system and dot system?
    or will the bit of fluid that remains in the syringes contaminate the other system?
    will an avid bleed kit work on a shimano system?
    Meh.
    Reputation: XSL_WiLL's Avatar
    You don't need a bleed kit for a Shimano system... You could just bled the Shimano like a car brake.
    Two Words
    HELLZ NO!
    Not unless you're looking to give yourself a reason to buy the next newest and most wonderful brake. Rubber seals in the two systems are designed to work with the specified fluid and will get destroyed in the presence of the incorrect fluid. Kiss any chance of a warranty buh-bye if you do try it, so DON'T DO IT.
    You are not what you own.
    Meh.
    If the syringes are clean and devoid of the other type of fluid... I see no issues.
    But again... you don't even need a bleed kit for the Shimanos.
    And most bleed kits are just a syringe and some clear rubber tubing. Go to a pet store/hardware store for the tubing and a pharmacy for the syringe. The Hayes uses a squeeze bottle... but I replace it with a syringe. Some bleed kits are specific to the brakes... for instance, fittings on the Hayes Nine are different than the fittings on a Juicy.
