Results 1 to 9 of 9
    Can you reuse compression fittings?
    I've got a set of XT M775 brakes that needs lines shortened. Are the barbs easy to get out, or are the barbs and olives one-time use kinds of things?
    Meh.
    Reputation: XSL_WiLL's Avatar
    They are supposed to be replaced.
    cougarbait
    Reputation: Lambdamaster's Avatar
    Nov 2008
    I am pretty sure the olive is not replaceable, as it is deformed once compressed. I dunno if you can manage to remove the barb with the olive stuck on it.
    09AS-Rsl/09Six
    Cut the olive and slice out the barb. Barb should be re-usable if you can get it out.
    NMBP
    Reputation: crashtestdummy's Avatar
    Jun 2005
    Quote Originally Posted by the-one1
    Exactly, I have reused them several times. I cut the olive with a cut-off disc in a Dremel.
    err, 27.5+
    Reputation: AL29er's Avatar
    As others have posted, in a pinch you can reuse the barb. But IMO it is hardly worth the effort. Only reason to go there is if you are in a pinch and can't wait to order up or find the correct parts. I try to keep spares for my brakes just in case
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    NMBP
    Jun 2005
    Quote Originally Posted by AL29er
    That's easy to say if you can find the spare parts. I reuse the barbs and machine new olives.
    Yep, sounds like I need to make a trip to the store, so I might as well get new barbs and olives. Thanks for the replies.
    err, 27.5+
    Both shimano and SRAM are good about using common olive and barb fitting across most of their product lines, so machining your own isn't likely to be necessary.
