Results 1 to 7 of 7
    Can you mix and match brake adapters?
    Is it possible to use a Hayes 180mm adpater on an Avid Juicy 7 Caliper since they're both International Standard? or Vice Versa?
    Reputation: scottay's Avatar
    yes, 185s are the same.......
    Meh.
    Reputation: XSL_WiLL's Avatar
    The Hayes v7 rotor is not 185mm like Avid uses. If you want to use the Hayes adapter, you must use the Hayes rotor as well.
    Just did it this week on my 8" For my Hayes Strokers. The Hayes adapter was 24 buck and the Avid 10. Used the Avid no prob.
    Reputation: stretch169's Avatar
    XSL_Will is right on the 185 though. The Hayes V7 is only about 178mm so the Avid rotor will rub the caliper, I learned this first-hand.
    Pivot Firebird, Tomac Snyper, KTM 250SX
    The ADAPTERs will all mix/match with the calipers.(use the juicey washer system also)
    Be more carefull when you mis-match rotors to adapters. Bigger adapters to slightly smaller rotors should work, but slightly less braking power/surface contact between pad/rotor....
    Quote Originally Posted by scottay
    Thank you for your response. I'm planning on using a Hayes adapter and Avid caliper for the V7 rotor.
