Results 1 to 3 of 3
    can i use non-shimano hubs with XTR discs?
    I would like to buy a new wheelset and I am running XTR discs. Do I have to replace with shimano disc wheelset or can I buy a chris king disc wheelset? Do Shimano calipers work with anything other than shimano-specific disc wheels?
    BLS439
    Reputation: BLS439's Avatar
    You can....
    Quote Originally Posted by -dude-
    You can use the Shimano Calipers with any wheelset that you buy. You would have to switch out the rotors. You can buy the 6 bolt rotors from Jenson.usa, last I checked they were $15, and slap 'em on your new wheel set. I run a CK wheelset with the Shimano 6 bolt rootrs.
    Make sure you get the Shimano rotors, as I am not sure what the different size tolerances are...the wavy ones might work?
    --BLS439
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    If you want the XTR rotor, DT Hugi makes Center Lock compatible hubs and Bontrager Race X Lite Disc wheelset (hub is made by DT) uses the same interface... But the brakes work fine with a standard 6 bolt rotor so you can use the wheels you want.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
  1. Why use shimano hubs?
    By thebronze in forum Wheels and Tires
    Last Post: 07-18-2004, 04:16 AM
  2. xtr vees or 6" rotor discs
    By qtip in forum 29er Bikes
    Last Post: 03-09-2004, 01:53 PM
  3. marco very much likes xtr discs!
    By marco in forum Weight Weenies
    Last Post: 02-24-2004, 04:55 PM
  4. cone wrenche size for Shimano hubs
    By PBK in forum Tooltime
    Last Post: 02-17-2004, 01:44 PM
  5. Replies: 4
    Last Post: 02-12-2004, 10:55 AM
