Results 1 to 6 of 6
    COOL BUZZ & TASTY S-TRACK
    Reputation: spacoli's Avatar
    Can I shim rotor at hub?
    I have two disc wheelset, and the rotors don't line up with the caliper the same.
    Could I shim the rotor away from the hub to keep the same distance between the caliper as the other wheelset?
    It would be only two shims, that should do it.
    I can fix it............... my dad has an awesome set of tools
    UKMac
    Guest
    I think it's possible
    but I don't know anyone who has done it. You would need to be sure to shim evenly so the rotor remains in the same plane (but I'm sure you have thought of that). I asked the same question when I bought my second disc set and ended up buying a second XT, 317, DT Revolution set because I wasn't comfortable with the other options (shimming the one set of hubs or re-shiming the caliper to change wheels).
    Yes.
    Quote Originally Posted by spacoli
    Yes, Syntace makes disc hub shims for that:
    http://www.syntace.com/02_produkte/detail.cfm?artid=757
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Yup. Syntace makes rotor shims.
    I think I saw some recently at Mtn High Cyclery - www.mtnhighcyclery.com
    Cyclist
    Reputation: striker's Avatar
    beer can
    cut a beer can open, pound it flat and trace a shim out of it. Zinn has this tip in his latest book.
    You can shim anything with a beer can.
    "Beer is proof that God loves us and wants us to be happy." -- Benjamin Franklin
    My cycling photos. Enjoy!
    VEGAN ATHLETE Racing
    Reputation: vuduvgn's Avatar
    Cans? They put beer in cans too?
    Weird.
    This weekend I took some beer caps, drilled holes in them and cut off the crimped edges. They make purty little shims for the caliper for fork connection. Ya can advertise yur favrite brew too.
    Take a look at and consider "liking" our VAR Facebook and VAR Instagram pages.
  1. DT Swiss 240S Disc rear hub durability
    By riverrat in forum Wheels and Tires
    Last Post: 09-28-2004, 03:12 PM
  2. where do I find a rotor shim?
    By pipspeak in forum Brake Time
    Last Post: 07-23-2004, 07:09 AM
  3. Front disc -to- Fixie only hub
    By itsdoable in forum Singlespeed
    Last Post: 03-23-2004, 09:41 PM
  4. 24h rim with 32h hub? Leave every 4th hole out?
    By Duckman in forum Wheels and Tires
    Last Post: 03-10-2004, 09:53 PM
  5. Which hub should I buy?
    By stoom in forum Singlespeed
    Last Post: 02-27-2004, 02:18 PM
