Results 1 to 5 of 5
    Apr 2005
    Can I fit an S-Works Epic with Disc Brakes?
    I'm looking at buying a slightly used '05 S-Works Epic with XTR rim brakes. Does anyone know if that bike can be fitted with discs or do I need to look at the S-Works Disc?
    Reputation: VTSEAL's Avatar
    The frame should accept the rear brake, just check the fork to make sure it is disc compatible, I believe on the first few off the line in '03 came without rear disc mounts. Also!! don't forget to check out the wheels, make sure it has disc compatible hubs, or you'll be buying a new wheelset too...
    Call the Specialized help line.877-808-8154
    Apr 2005
    Quote Originally Posted by VTSEAL
    Thanks for your help!
    Reputation: Bladerunner's Avatar
    Jan 2005
    I have also heard that the brain on the rear shock might interfer with the line routing.
    You might want to check that too.
    Reputation: shiggy's Avatar
    Dec 1998
    As per the Specialized web site (who'd da thunk ta look there! ) the frame and fork are disc compatible. The hubs may or may not be. Probably not.
    mtbtires.com
  1. What are the BEST brakes on EARTH?!
    By norwoosg in forum Brake Time
    Last Post: 02-24-2005, 10:38 PM
  2. 05 Team Scalpel or 05 S Works Epic Disc?
    By vs779 in forum Endurance XC Racing
    Last Post: 02-17-2005, 03:24 AM
  3. Disc...or V's...
    By BThor in forum Singlespeed
    Last Post: 01-20-2005, 04:47 PM
  4. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  5. regular brakes and disc brakes
    By joshua_msu in forum Brake Time
    Last Post: 03-05-2004, 09:07 PM
