Results 1 to 3 of 3
    Caliper seal/oring/rebuild question, Formula brakes
    2011 Formula The One. User error caused a damaged piston seal in the caliper body. Are these user serviceable? I see on the exploded diagram they seem fairly straight forward to work on, although I have never done this before. I have however bled brakes, installed new lines, etc. It appears there are three orings/seals associated with the piston, one that seals the system from the back cap, and one for sealing each piston. I haven't attempted to open the caliper up yet but it appears as if I damaged one of the orings that seals the piston. I would do it by putting the caliper body in a vice, in such a way as to not damage it of course, unscrew the back cap(assuming no proprietary tools are required), and the rest would kind of be obvious? Any advice, comments?
    Reputation: FORMULA Canada's Avatar
    Mar 2012
    Hey there,
    Caliper cap removal is not required to service the pistons and o-rings. Being a 1 piece design, the cap is only there as an access point during machining to the caliper bores.
    For further info please contact:
    Formula North America- 803-547-2010
    Formula Canada-604-459-0070
    Mar 2012
  1. Noob question on formula rx brakes
    By Learux in forum Brake Time
    Last Post: 08-27-2012, 06:46 PM
  2. RP23... Seal kit or full rebuild?
    By k6monster in forum Shocks and Suspension
    Last Post: 04-17-2012, 10:46 AM
  3. formula rx and the one caliper help
    By neveo in forum Brake Time
    Last Post: 01-26-2012, 06:39 AM
  4. Formula The One 2010 caliper bore cap tool
    By J. Random Psycho in forum Brake Time
    Last Post: 01-25-2012, 06:17 PM
  5. Juicy 5 Caliper Rebuild Kit
    By s0ckeyeus in forum Brake Time
    Last Post: 10-20-2011, 01:01 PM
