Results 1 to 5 of 5
    Caliper/Rotor Swap Front To Rear. Won't fit there?
    OK, so I had a fork with an IS mounted disk brake and 160mm rotor. I got a new frame/fork. The new fork had a post mount and the frame an IS mount. I planned to just get a new brake for the front and use the IS brake from my old fork as a rear brake. Unfortunately the rotor is too big to be used with that caliper on the rear. If this is common and someone knows what to do, do I just need a smaller rotor and I'm good? If so, what size would I need?
    Reputation: mitzikatzi's Avatar
    What model/brand are the brakes?
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Tektro Novela. Not that good, but since I already have them and it's just in the rear I'd like to use them if I can.
    EDIT: Not the ones with the post mount and IS adapter. Mine are a few years+ old and built as IS mount. There's a picture of them in the forth post down of this thread.
    Diffence between Tektro IO and Novela
    dru
    dru is offline
    You need a 140 mm rotor for the rear and you should be good, but see below:.
    Just to clarify; you have a 160 mm rotor and IS caliper from an IS fork that you want to use on the frame as a rear brake right?
    Drew
    occasional cyclist
    That's what I thought I needed, but couldn't seem to find that info stated anywhere. And yes, I'm trying to use the IS caliper from an IS fork on the frame as a rear brake. Thanks for the help.
  1. I built a singlespeed. help me with this tensioner?
    By CommuterBoy in forum Singlespeed
    Last Post: 02-08-2012, 09:43 PM
  2. Replies: 3
    Last Post: 01-13-2012, 04:30 PM
  3. Can I use a XTR 10spd front derailluer with 9 speed shifter?
    By trojans1993 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-12-2012, 05:15 PM
  4. Rear shock and fork upgrade for KHS XC-104
    By rkj__ in forum Shocks and Suspension
    Last Post: 01-12-2012, 02:30 PM
  5. Replies: 2
    Last Post: 01-10-2012, 03:53 PM
