    New question here. Caliper and hose O-rings
    Hello everyone, I need new O-rings for my Formula B4 brakes: the two hose O-rings for both ends (4 rings total) and two grub screw rings. However, I cannot find these on there own but instead in sets combining in price to 50 ($75). Bit steep for 6 rings
    Does anyone know how I can get around this? I know that the avid juicys would also work but I can't find an O-ring only set from them either. I was also wondering if there was a way of making them? Perhaps by chopping a cable or with a rubbery glue.
    Any ideas would be great, thanks a lot - Dylan
    ...idios...
    Reputation: SteveUK's Avatar
    You'll be able to buy o-rings from any decent hardware or plumbing store, or size them and order them online.
    And welcome to MTBR.
    Diogenes
    Are there any sites you could suggest? And thanks for the welcome
    ...idios...
    As I said, large hardware stores and plumbers merchants will carry o-rings of the size you need, so you're highly likely to be able to find them locally. A search through your local business 'phone book should yield results. Even if they don't hold stock, a good store will e able to tell you what size you need - if you show them the old ones - and where you'll be able to get them.
    Diogenes
