Results 1 to 7 of 7
    Binned
    Nov 2008
    Burned Brake Rotor Assistance
    While on a ride tonight, I noticed that my rear brake was acting strange. The caliper was making a popping sound whenever I squeezed the lever. The brake worked normally though so I continued on. As I progressed I start hearing a jingling sound from the rear of the bike as I rode down the uneven terrain. I stopped and noticed that my rear rotor was coming loose. Didn't have the proper tool to tighten it up with me so I proceeded (catiously) down the hill to get home.
    When I got home and had a good look in the light, I could see that the rotor had pretty much turned dark.
    It still seems to slow and stop normally, though.
    Is the rotor dust or is there something I can do to it to remedy it's condition, other than tighten it up and go?
    It's a 160mm Magura Storm SL rotor with plenty of thickness left.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    I just had a similar experience with my Hope's . . . . took them down a run and part way down, the front was making similar noises to what you are describing. I stopped and could see a dark streak all the way around the braking surface. Had to get home, so I let them cool and continued down the run . . . by the time I got to the bottom, the noise was gone and the rotor is clean again.
    I think my issue is that I took them down a run that they weren't ready for . . . I have only about 50 miles on them don't think my pads are fully bedded in yet (seems to be talking FOREVER). Are your Magura's still pretty new?
    I think I'd tighten it up and go . . . see what happens. Can't get any worse really, can it?
    Its probably warped too- which was probably causing the popping noise. Your best bet is to buy a new rotor honestly.
    Binned
    Nov 2008
    Just ordered a new set of rotors. I will ride on this rotor until the the set shows up. Between now and then, I will decide whether or not this rotor is gonna continue to do it's job.
    If I should die while trying to find out...the answer to my question will, "NO".
    Geez I have blued up my rotors several times...smoking hot...(they did not loosen off)...
    I just took a small chunk of sandpaper between my fingers and rotated the disk for a minute or so...
    Cleaned up real nice.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    I've had several rotors turn blue ... never did a thing about it and it eventually wore off and the brakes worked fine the whole time
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Binned
    Nov 2008
    Quote Originally Posted by jeffscott View Post
    K, thanks. That's pretty much what I figured. I still needed the extra set of rotors though. I like to keep a spare one of everything in my "bike shop" closet.
  1. Replies: 1
    Last Post: 08-10-2010, 07:07 AM
  2. Prophet/Avid Ultimate brake line assistance needed
    By brows141 in forum Cannondale
    Last Post: 03-05-2010, 02:49 PM
  3. brake rotor
    By t1deep in forum Ibis
    Last Post: 12-15-2008, 11:08 PM
  4. Replies: 4
    Last Post: 02-29-2008, 06:02 PM
  5. Replies: 7
    Last Post: 08-24-2005, 05:26 PM
