Results 1 to 3 of 3
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    Broken Elixer CR lever...
    I've never had to mess with this kind of thing but I have had what felt like excessive play and slop in my front brake lever for some time. I haven't taken the lever apart to investigate as of yet but today, while looking into the area where the plunger is connected to the lever, I noticed an obvious crack and de-lamination in my lever allowing the excessive slop.
    I assume I can get a new lever from Avid but is there a source for an aftermarket, possibly better, brake lever for Avid's Elixer CR? Any good sources for an OEM lever OTHER than Avid?
    TIA
    Dec 2010
    You can find cheap replacement levers on eBay, not sure about anything aftermarket for the older CR brakes, though...
    Mr. Buck E. Fikes
    Thanks for the reply. I pulled the lever off yesterday and used a 2 part epoxy on it. It's back together again and it appears the repair is stout. Checking ebaY, the range of pricing was from $45 at the cheapest and $80+ for the same thing at the high end. Hopefully I won't need a replacement after all as the cost is absolutely ridiculous!
  1. elixer brake lever position, vs shift lever
    By thecanoe in forum Brake Time
    Last Post: 10-25-2012, 04:04 PM
  2. Sram XX (Elixer) lever is locked out - help!
    By dcubed in forum Brake Time
    Last Post: 09-19-2012, 09:02 PM
  3. Avid Elixer 5 lever reach
    By stygz1 in forum General Discussion
    Last Post: 04-09-2012, 10:05 AM
  4. bent brake lever elixer
    By eerieclown in forum Brake Time
    Last Post: 12-04-2011, 04:00 PM
  5. Elixer R - No lever play
    By Tinshield in forum Brake Time
    Last Post: 02-02-2011, 08:44 AM
