Results 1 to 12 of 12
    Reputation: HiFly's Avatar
    Broken breaks, seeking replacement. Little help please?
    Well I finally managed to break my 2003 Magura Julies hydros, I guess that's what happens when you take a tumble at 30mph onto hard pavement. Bad news is I can't seem to find any replacements that match the original hardware. While I can look around at possible replacements like the Hayes Stroker trail or the Avid Juicy 7 I can't make a decision without being sure that the new breaks will fit. It's easy to measure items like the fork and frame mount bolt spacing dimensions while others like the hub flange offset are more difficult. Given the bike below and the component list from the webpage can anyone point me in the right direction? I'm sorry in advance that I can't pass along the original manufacturer page but it seems to no longer exist.
    Thanks in advance for any and all help
    2003 Tomac 98 Special Comp Information
    Broken Parts:
    Front Master Cylinder - Clean Break
    Rear Master Cylinder - Shattered
    Front/Rear Calibers - Cracks around mounts
    I suppose I should write something here.....
    Never trust a fart
    Reputation: frdfandc's Avatar
    You should be able to use either one of those BRAKE setups without any issues.
    But it would be easier to look at your BRAKE system with a current picture of the mounting points instead of a web picture from the drive side when BRAKES are on the non drive side.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Hub flange offset is produced to a international standard (with some tolerance).
    Thanks for the quick reply, I'll post some detailed images after class tonight. Of the two brake systems, is there one you would recommend over the other?
    Here you go, sorry about the grain/blur/ugly template. Good news is that I found someone with a replacement rear break.
    Thanks again for all your help.
    Never trust a fart
    Looks like the standard ISO 51mm brake mount. You can use pretty much any brake system you want.
    Meh.
    Quote Originally Posted by frdfandc
    No. That's a 74mm post mount, not an ISO 51mm.
    Old man on a bike
    Maybe it's time to change your signature to something about the obvious differences between post mount and IS mounts
    suum quique
    Never trust a fart
    Glad you came along and made such a constructive post there FOOL. I don't know what I would have done without it. My world would have came to an end.
    XSL_WILL - thanks for the correct.
    Reputation: Curious-George's Avatar
    lol you actually put the spelling differences in your signature
    Old man on a bike
    Will only beat me to it...nice emoticon!
    suum quique
    Never trust a fart
    I thought the emoticon is good. I have so much more. lol
