Results 1 to 2 of 2
    Reputation: HPilot's Avatar
    Brand New XTR Discs rubbing ONLY when....
    sitting on the bike and pedaling.. In the stand they are A-OK. When riding it seems that the rotor is not 100 true. This is strange, but it seems to be caused by the weight on the rear.
    I checked the skewer, hub bolts, all other things. It is only one fraction of the disc that rubs, and it's annoying while riding. Because these are brand new, should I just let the pads 'rub out' and it will eventually go away or should I take off the disc and flatten it to 100% true? I can see it wobble ever so slightly- enough to contact the pad slightly under wieght.
    "A witty saying proves nothing."- Voltaire
    Reputation: shiggy's Avatar
    Dec 1998
    What frame, hubs?
    Yes, you should true the rotor.
  1. Can XTR discs be used with other brake calipers?
    By Ziggy-Stardust in forum Singlespeed
    Last Post: 03-08-2005, 07:20 PM
  2. 8" XTR discs VS. 8" Saint disc's-ANYONE USING THEM?
    By thjrollins in forum Brake Time
    Last Post: 08-19-2004, 09:17 AM
  3. levers to go with XTR discs
    By jam in forum Brake Time
    Last Post: 07-01-2004, 07:14 AM
  4. xtr vees or 6" rotor discs
    By qtip in forum 29er Bikes
    Last Post: 03-09-2004, 01:53 PM
  5. marco very much likes xtr discs!
    By marco in forum Weight Weenies
    Last Post: 02-24-2004, 04:55 PM
