Results 1 to 16 of 16
    Brakes Purchase Question
    Some websites do not state the length of the hoses or anything about hosed when you order a set with caliper, rotor and lever. Do Shimano brakes come from the factory all set up?
    All the pairs of brakes that i have brought have always come ready to fit.Including all fittings hoses and bled.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I bought Shimano LX hydraulics for my latest tough hardtail:
    http://www.chainreactioncycles.com/K...x?ModelID=7911
    http://www.chainreactioncycles.com/K...x?ModelID=7909
    They came ready to bolt on, with some more hose than I need, but I managed to arrange them somewhat neatly without shortening.
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    got my M765 from CRC 2+ years ago and they came all bled and ready to go ...
    what kind of frame have you got? and size wise as well?
    usually the hoses are long enough to fit otherwise it is a simple job to change the hoses or to shorten them ...
    My Cannondale frame is quite small. My measured hose size requirement is about 750 in front and 1250 in back. It is not a suspension geometry so the front is really short. I heard that the standard size for Shimano brakes is 800 and 1350 - can anyone confirm.
    I'm looking for easy install - don't want to bleed them if I can avoid it. I did see a shop manual on the Shimano website that showed that all of their hoses can be shortened without bleeding, by following some steps (pull lever, remove at caliper and cut, etc etc) so I guess if they have to be shortened it may not require a bleed.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Quote Originally Posted by Molly55
    My Cannondale frame is quite small. My measured hose size requirement is about 750 in front and 1250 in back. It is not a suspension geometry so the front is really short. I heard that the standard size for Shimano brakes is 800 and 1350 - can anyone confirm>
    shimano hoses come in 900mm (front) and 1300 or 1700mm (rear) lengths
    Have any of you ever shortened a Shimano hose without having to bleed, per their shop manual?
    ups and downs
    Yep, just following the instructions for hose shortening on XTR brakes worked just fine.
    Quote Originally Posted by rockyuphill
    ditto..just avoid wiggling the hose..
    excellent.
    I think I may buy from somewhere in the US. Now to decide which brakes I want - Shimano, Juicy, etc. I like them all.
    ...idios...
    Reputation: SteveUK's Avatar
    "Shimano, Juicy, etc. I like them all."
    Why do you like them all?
    Diogenes
    Because I have ridden bike with Shimano, Juicy, Stroker, etc and I like them all. I may go with Shimano. The performance and pros and cons of each may balance out, but Shimano has served me well for decades and in return I tend toward the brand. Not married to it, just like it a lot.
    Nov 2007
    check out,the slx brakes....great bang for the $$$$
    local trails rider
    Aug 2005
    SLX and XT should be good. I am really happy with the LX pair I mentioned above.
    wyrd bi ful rd
    ... Shimano has served me well for decades and in return I tend toward the brand ...
    good enough reason ...
    advice from this forum can be overly biased ...
