Results 1 to 6 of 6
    Reputation: js_paddle07's Avatar
    Brakes driving me crazy!
    My pads were rubbing my rotors; so much that it was actually binding the wheel. I took the wheel off and inserted the bleed block. I pulled the lever a few times and left the bike overnight.
    I went to ride today and my lever pulls all the way back to the bars before the brakes engage. I didn't mess with the fluid or make any other adjustments. The pads are fairly new and the brakes were bled not too long ago at my lbs. What's the deal?
    The brakes are Avid Elixir Rs on a Stumpy.
    Please help, thanks.
    Whenever I see an adult on a bicycle, I have hope for the human race. ~ H.G. Wells
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Try squeezing the lever a few more times . . . by inserting the bleed block, you pushed the pads all the way out and thus they need to reset to the current pad thickness (which would result in the lever being VERY soft the first few pulls).
    If after several pulls, its still pulling back to the bar, then you've got some problem solving to do . . .
    Edit: Sorry if this is obvious . . .
    Reputation: Shalom's Avatar
    Nov 2008
    Further to what 007 said, if you are still experiencing squishiness, I would recommend bleeding the brake in question. The key being, when you get to the step where you release the lever after flushing the line and bleeding the caliper, to release the lever very slowly. In effect, you are using the pressure from the syringe to push the lever out. The slower you go, the better.
    Edited to add link - Elixir bleed
    Thanks guys. I actually did about a 5 mile ride yesterday with the squishy brake. Not the safest idea, but I wanted to see if it would fix itself. It didn't. This brake was bled by the lbs over the summer. I honestly haven't put 30 miles on it since then. Why would it already be failing???
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by js_paddle07 View Post
    Sounds like it wasn't bled properly is all. Take it to a new LBS or do it yourself. Its not terribly hard and there are lots of video's out there on it.
    If after a GOOD bleed you are still having issues, then you have a leak somewhere, possibly bad seal, etc. But start with the simple (and probable) culprits first.
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    If the LBS did it recently, I'd bet that they did not close the bleed valve all the way, or the reservoir is leaking from not being sealed properly by the same LBS. Now there is not enough fluid in the system, and there is air in the system. Needs to be bled again.
    Learn to do it yourself. Very easy and you will pay better attention than anyone else to your bike. Good luck.
    My name is Chris and I ride a Prophet 650b with a Lefty.
  1. So this is driving me crazy...
    By dr13zehn in forum Brake Time
    Last Post: 02-05-2010, 01:27 PM
  2. flats are driving me crazy!
    By cliffslocal in forum Wheels and Tires
    Last Post: 10-08-2009, 10:48 AM
  3. This guy is driving me crazy...
    By Cody Broken in forum Vintage, Retro, Classic
    Last Post: 07-11-2007, 11:36 PM
  4. Has the wind been driving you crazy?
    By borregokid in forum Arizona
    Last Post: 01-28-2006, 06:17 PM
  5. Avid's Driving Me Crazy......
    By onepivot in forum Brake Time
    Last Post: 06-03-2004, 08:15 PM
