Results 1 to 2 of 2
    Reputation: henry9419's Avatar
    brakes/braking terminology
    im just starting learning more about brakes and looking for a new set of discs but im getting confused by some of the different terminology so i was hoping we could put together a list of some sort with related terms and how they affect my/your decision in buying brakes
    2009 Jamis Trail X2
    2002 Raleigh Mountain Scout
    2008 Trek fuel ex7
    A start.. in simple terms
    Hydraulic Brakes: brake lever pushes fluid down the hose to the caliper causing the pistons to clamp the metal/organic brake pads down on the spinning rotor
    Cable Brakes: brake lever pulls the wire upward causing the rubber pads to camp down on the rim
    Rotor: Metal disc mounted in the center of the wheel which is gripped by the brake pads to slow the rotation of wheel
    Caliper: brake mechanism which, through moving pistons, clamps down on the rotor to slow the rotation of the wheel
    Brake Pad: Flattened material which, when pressed against the rotor, slows the rotation of the wheel.
    Bleeding: the process in which air is removed from the caliper and hose and replaced with more fluid
    Reach: the distance one must outstretch their fingers to be able to grip the lever
    Play: the distance you can pull the lever before the pistons begin to engage
  1. Replies: 2
    Last Post: 08-10-2011, 04:48 PM
  2. Code R's too much braking rear braking power?
    By mefistofeles in forum Brake Time
    Last Post: 12-07-2010, 08:10 AM
  3. Replies: 13
    Last Post: 08-15-2008, 06:19 PM
  4. LED terminology
    By sean newell in forum Lights DIY - Do It Yourself
    Last Post: 04-17-2008, 09:07 PM
  5. terminology help
    By isleepsober in forum Beginner's Corner
    Last Post: 03-15-2007, 07:30 PM
