Brake upgrades vs Completely new system...
I have a feeling I know where this thread will go, but I thought I'd ask anyway...
Has anyone here done a brake upgrade - going from a 160mm rotor, to 180mm rotor, when running hydraulic brakes? Was there much of a performance difference once you did the upgrade?
I'm considering doing this, or just scrapping the current brake system altogether, and just going with a higher end brake system.
Any input would be greatly appreciated.
There is a noticeable increase in power because you get more leverage and lower operating temperatures...however what exactly is your problem with your current setup?
Nothing wrong with it really, I'd just prefer a more solid brake feel. I'm running the stock Avid Juicy Fives, they stop well enough, I'd like more stopping power, these do not inspire confidence on a steep downhill run.
I'm thinking about going to AVID XX's.
Try a bigger rotor 185mm or 203mm. (one size bigger on the front then the rear). Some say 185mm is as big as you should fit to a quick release wheel others disaggree, also check what the max is for your fork.
Try better pads eg EBC Red
Try Braided steel hose.
Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
Bike to the Bone...
I went from 160 to 200 a while back on Shimano XT brakes (2005 model), and I did notice the difference. Not day & night, but it was positive.
If your looking to upgrade to gain additional power, this would not be the brake I would select. There are much better alternatives on the market.
Avid XX's are not made to have a ton of stopping power, they are weight weenie world cup XC brakes. I would steer you to 2012 Shimano XTR's.
By bikedreamer in forum Brake Time
Last Post: 03-31-2010, 06:14 PM
By Damitletsride! in forum Endurance XC Racing
Last Post: 12-12-2009, 02:33 PM
By _ALX_ in forum General Discussion
Last Post: 12-02-2007, 02:33 PM
By -=phelan=- in forum Brake Time
Last Post: 08-20-2007, 07:12 AM
By whftrout in forum Brake Time
Last Post: 05-09-2007, 07:02 PM
- You may not post replies
- You may not edit your posts
Forum Rules
