Results 1 to 7 of 7
    Reputation: NHmtnbke's Avatar
    Brake upgrade...
    My 2004 Trek 4300 is in need of new brakes. Bike is stock. Just wondering would it be easy to convert to disk? What price range would you think? If so what are your suggestions for parts and what needs to be done?
    Are my stock rims compatible? I'm looking for winter project.
    Brian
    Hubs must be disc compatible or you will need new hubs. Frame must have disc tabs on rear or you will need to swap frames. Fork must have disc brake tabs/posts or you would need a new fork.
    Quote Originally Posted by branthopolis View Post
    I want to say yes, but not 100%. I'm at work right now, will check in the morning.
    B A N N E D
    TrekBikes.com Bike Archive | 2004 4300
    The fork has disc tabs.
    The frame probably doesn't have disc tabs but you can get a bolt on frame disc adapter for this bike if it doesn't.
    The hubs probably wouldn't be disc compatible so you'll need new wheels.
    With mechanical discs you can use your current brake levers but you'll need new brake cables and housings.
    If you currently have a brake/shifter combo set up and you were to get hydraulic discs brakes you'd also need to buy new shifters.
    Brakes/Brake Adapters/Rotors - $102 - Avid BB7 Mechanical Disc Brake '10 at JensonUSA.com
    Wheelset - $95 - Shimano Deore Disc/Rhyno Lite Wheelset at JensonUSA.com
    Cable & Housing - $17 to $30 - Jagwire Hyper Cable and Housing Kits at JensonUSA.com
    or Jagwire Ripcord Diy Brake Kit at JensonUSA.com
    Disc Frame Adapter - $34.50 to $38.50 - Trek Klein Gary Fisher Rear Disc Brake Adapter OEM MADE | eBay
    or Rear disc brake adapter 4 Gary Fisher Trek Klein Juicy | eBay
    Here's a good value brake kit but you'd need to buy new shifters if you currently have the brake/shifter combo set up.
    Brake Combo - $121 - BlueSkyCycling.com - Avid BB7 Disc Brake Combo Kit 2010
    Shifters - $21 - Shimano Alivio SL-M410 Shifters at JensonUSA.com
    Quote Originally Posted by cobba View Post
    Thats perfect thank you.
    cobba, you are correct forks have tabs frame does not.
    Fat-tired Roadie
    Nov 2007
    You can get most of the benefit of a disc setup if you just do the front. I'd be more inclined to do that than to use an adapter for a non-disc frame.
  1. V Brake Pad Upgrade
    By RagerXS in forum Brake Time
    Last Post: 06-11-2011, 06:57 PM
  2. brake upgrade
    By ridefreeride in forum Beginner's Corner
    Last Post: 12-25-2009, 12:50 PM
  3. brake upgrade?
    By tmonck in forum Brake Time
    Last Post: 10-14-2008, 06:32 AM
  4. Replies: 0
    Last Post: 09-24-2007, 04:44 PM
  5. Inexpensive V-Brake to Disk Brake Upgrade
    By Mudd in forum Brake Time
    Last Post: 02-07-2007, 06:11 PM
