I am starting a mix and match project between different brake master cylinders and calipers. While this is common on motorcycles I can't find much info on doing it with bicycles. No one seems to list dimensions for their brake systems so I am gonna start a data base.
Here is a good lesson on what matters in a radial master cylinder.
In the caliper is the diameter of the pistons and how many there are.
With both those peices of info we can make informed desicions on what M/C will work with which caliper no mater who makes it.
Any help is appreciated
First entry:
Brake M/C Bore leaver/plunger inter-axis Caliper Piston(s)
2008 Magura Marta 10mm 13mm 2 @ 21mm
Results 1 to 1 of 1
Hot DealsContestsLatest Mountain Bike ArticlesVideosMTBR on Facebook |
LinkBack URL
About LinkBacks
