Results 1 to 6 of 6
    Brake Rub and odd wear
    Hi,
    I have a 2009 Kona Five-O. I've been having issues with my front brake ever since i got it. I have trouble fitting the rotor in betweent he brake pads when i put the wheel on. and when i do get it in there. I see a gap on one side of the rotor and not the other.
    Also i was looking on on the inside of the rotor, and i see a lot more wear on the inside edge than the outside. Is there a way to fix the one pad that causing the rub and wear on the rotor?
    What brakes are they?
    It sounds like a set up issue.
    Lead by my Lefty............... right down the trail, no brakes.
    Hayes Stroker Ryde. Stock ones that came with the bike.
    bump
    anyone have any suggestions?
    B A N N E D
    Hayes Stroker Installation & Service Manual: http://www.hayesdiscbrake.com/Stroker45-21883EnglishWeb.pdf
    Meh.
    Reputation: XSL_WiLL's Avatar
    Read the posting guidelines. Do not bump your own threads.
    Read the manual.
    Reset the pistons, center the caliper.
