Thread: Brake Rotors
    Brake Rotors
    Is there really any difference in brake rotors (Avid vs Shimano, etc). Does it matter if I use Shimano rotors on an Avid setup?
    Reputation: Shalom's Avatar
    Nov 2008
    As long as the size of the rotor is correct, you should be fine. There might be more noise with various rotor designs over others, but it should still work.
    B A N N E D
    Some Shimano rotors are for use with resin/organic pads only.
    avid or hayes
    can avid rotors be used with hayes brakes and vise versa? Any compatibility issues? Which rotors are better?
  1. disc brake rotors bend, when I brake?
    By chimpanzee00 in forum Beginner's Corner
    Last Post: 01-23-2017, 02:02 AM
  2. Brake Rotors
    By cale399 in forum Weight Weenies
    Last Post: 03-06-2009, 07:37 AM
  3. Brake Rotors
    By Sean555 in forum Kona
    Last Post: 02-25-2008, 05:43 AM
  4. Super trick brake rotors “Radical Rotors”
    By Uncle Jimmi in forum General Discussion
    Last Post: 12-29-2007, 12:02 PM
  5. brake rotors...
    By sirbikesalot in forum Turner
    Last Post: 09-08-2005, 02:21 AM
