Results 1 to 33 of 33
    Gumnut Peddler
    Reputation: Grinderz's Avatar
    No good Brake/Rotor sound at specific speeds
    Fitted up new wheels to my bike a few months ago. No dramas.
    Recently my bike has developed a problem where when I am riding at speeds faster than 32km/hr (20 miles) the front end starts to 'ching/humm' with every rotation of the wheel. The faster I go, the more audible it becomes.
    Speeds slower than this, no problem/noise whatsoever.
    I have checked the clearance of the rotors and it doesn't appear to be rubbing or have any visible wobble. There is no brake drag and the wheel when spun by hand will spin for ages. The brakes are also working fine, but this noise is really starting to annoy me. The only thing that makes it stop is by putting the brakes on or dropping my speed. Neither of which I want to do during my sprints.
    Has anyone experienced this before? It aggravates me on every training ride and I need to end it
    Brakes are Juicy 7 with organic pads. Pads are new, brakes have been rebuilt. Rotor is a hayes V7 from memory.
    Cheers
    Burning fat, not oil.
    nvphatty
    Guest
    How did you determine it's the brake/rotor? are the spokes tensioned properly after a few months of use?
    Gumnut Peddler
    I just figured it was the brake/rotor due to the fact that it is a similar sound to when you have a small warp and it strikes with each rotation.
    Spoke tension never even crossed my mind. Might do a quick lube test tomorrow and see
    Reputation: Cenzobear's Avatar
    Oct 2012
    Quote Originally Posted by nvphatty View Post
    I may be incorrect, but spoke tension shouldn't affect the rotor in any way. The rotor is directly mounted to the hub, which is mounted to the dropouts, so the only thing spokes should address are wheel straightness. I had his same issue with crappy tektro rotors, they were slightly out of true and heat development made them even worse.
    2013 Rockhopper 29- The hot rod fun bike
    2013 Stumpy HT Comp 29- The racin' machine
    Gumnut Peddler
    Quote Originally Posted by Cenzobear View Post
    You are correct about how the rotor mounts. BUT I could possibly be incorrect with where the sound is coming from, hence the spoke tension comment
    nvphatty
    Guest
    IF in fact it is the rotor hence why i enquired about it. if spoke tension is on the loose side it can easily effect the hub-rotor etc.
    That being said audible noises and their harmonics can come from numerous sources hence another reason why i asked how he determined it was the rotor/brakes.
    Binned
    Nov 2008
    Sounds like there is some flex going on somewhere since you only hear it when you are on the bike.
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    What hubs and what axle type up front?
    It could be minor hub/bearing play or the axle in the fork.
    Gumnut Peddler
    Running Stans 3.30 hubs with the 9 QR
    I will try and get a video up this weekend of the noise it makes. The front basically goes 'ching ching' 'ching ching' 'ching ching'
    I <3 dirt
    Oct 2010
    I'd check if your hub is tight and maybe snug the qr up a bit.
    Jun 2012
    Do a test ride with the front pads removed. make sure you don't accidently squeeze front brake by securing lever by taping something between handle and brake lever.
    Ted
    Ted is offline
    Ted in real life
    Reputation: Ted's Avatar
    I had a similar problem with BB7 brakes. It was due to running knobby tires on the road at certain speeds. I guess a vibration would be at the right frequency to cause the pads to contact the disks. I never noticed it on trails probably because I was going slower or the trail was rougher with its own vibration pattern. I switched to smooth tires for road rides and the noise went away.
    Jan 2013
    Quote Originally Posted by Grinderz View Post
    Cheers
    I know that "ching ching" problem all too well. Had it on my bike a while back.
    When I first bumped into the issue of brakes looking to be adjusted and sounds only starting after certain speeds I was running 203mm rotors without spiders (regular cheap-o Shimano Alivio level) and rolling on 2.4" Nobby Nic tires.
    After struggling with the problem for a while I concluded that the issue was caused by resonance in the rotor, despite being tightened properly to the hub.
    Large diameter rotor was resonating enough to occasionally hit the brake pads at certain speeds and it only occurred with heavily knobbed tires. Smoother tires didn't have the same issue.
    Also the resonance was more noticeable at corners while riding on pavement.
    Now I only run rotors that have a spider structure because they are considerably stiffer and don't resonate at high speeds even with rougher tread patterns.
    I would check that the rotors are tightened properly and the brake is adjusted in the center so you could avoid the occasional hit on both sides. If that doesn't fix it, then I would try stiffer rotors. Or smaller size, but that would affect braking power too. (Smaller diameter is stiffer than bigger ones.)
    Hope this tip is at least partly useful.
    Reputation: dirtyjack's Avatar
    Do your spokes pass very close to the caliper body? I had to shim out my rotor I order to move the caliper out so my spokes wouldn't rub. It may not rub when the wheel spins slowly but when it flexes it could.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Reputation: supersedona's Avatar
    Dec 2012
    Resonating rotor. Only some rotors will do it. To my knowledge Coda and Hayes rotors will not, but Formula and Avid will. Depends on the tires as well, as it is influenced by vibration of the tread. Usually my incidences of such were around 12-15 mph with mud tread, much higher speed if semi slick was used. Motivation to ride above the threshold
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    On your left.
    OP - are you absolutely sure the rotor is dead true? Verified how? Any warpage will cause this issue.
    M
    Gumnut Peddler
    Quote Originally Posted by Motivated View Post
    I have visually inspected the front rotor by spinning and looking down through the caliper and also front on and cannot see any wobble. Spinning slowly by hand and looking through the caliper I cannot see or hear any contact with the pads.
    On your left.
    That's good, but you can also try to check by slowly sliding your finger, tire lever, etc closer to the rotor while spinning.
    You can also try to clean the rotors with isopropyl alcohol and maybe sand the rotors and pads and redo the bed-in process.
    M
    Gumnut Peddler
    I try to avoid touching my rotors with my fingers. GoPro is now charged, so hoping to get some footage on tomorrows training ride.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    kinda interested in this.. never heard of this issue... wondering if its something beside the rotor? the vid might help see if you can mount on the fork or head tube... pointing down at the brake....?
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    nvphatty
    Guest
    sandpaper/emory cloth transfer adhesives to said parts and make for not a great braking surface even after being cleaned with IO or brake cleaner.
    I only ever have this noise when I've got the rotor rubbing very slightly on the pads. As slow speeds the energy transfer with the contact is so low its hard to tell you've got problems....but as your speed increases so does the friction/energy release - and hey presto you've got audible effects.
    The second contributing factor is you on the bike....and the flex that the extra weight causes. You could set up the brake perfectly with no rub, but have rub when you're riding....now THIS effect I've seen a lot - especially during cornering.
    Gumnut Peddler
    Here is a link to the video. This is the closest I could get the cam to the caliper.
    Noise - YouTube
    Reputation: Bikemaya's Avatar
    Sep 2012
    That actually sounds like loose metal rattling against something, not any sort of rubbing... Check that everything is tightened down, including the adapter and caliper.
    Gumnut Peddler
    Caliper is tight and same again for the rotor. Checked them last night. Will check the hub today
    Oct 2007
    sounds like the speedo sensor is loose on the spoke to me... kida weird sound thou for sure...
    Save Jesus
    Reputation: beanbag's Avatar
    test to check for loose things:
    pick up the front of the bike and let it drop. Catch the bike on the first bounce. if anything is loose, it will rattle.
    test to check for rotor resonance:
    very lightly drag the brake. Does the noise go away?
    To damp the rotor:
    wrap electrical tape either between the spokes of the rotor, or between a rotor spoke and wheel spoke, making sure it clears the caliper.
    Another possibility is that once you put weight on the bike, the fork legs and hub shift around just a little bit such that the rotor tilts over. Most forks have a spring in only one leg.
    Have somebody else sit on the bike and lean forwards, and you check that the rotor is still centered.
    Oh wait, a much easier test is to lean the bike over sideways while going over 20mph and see if the noise goes away.
    Sounds like rotor rub, my old M755 XT brakes would do the same thing when I went fast enough. Leaning the bike to one side would make it worse, leaning it the other way would make the noise go away. Nothing I could do about it, those brakes had an uncomfortably small clearance between the pads & rotor, once I got going fast enough the imbalances in the wheel & tire combined with the flex of the fork under my weight would be enough to make the pad brush the rotor.
    In your case, have someone else sit on the bike and weight down the front wheel. Check which way the caliper/rotor moves, then adjust such that the caliper is centered when the bike is weighted down. This should help, but depending on how close the clearance is it might not be enough to stop the noise entirely.
    Gumnut Peddler
    Kit was put through the brakes just before I put the new wheels on, and never had this issue with the old wheels.
    Save Jesus
    play in the bearings on the new wheel.
    On your left.
    Sounds like the caliper is hitting the spokes or the spring clip is tweaked and hitting the rotor. Check it.
    M
  1. First ride: Rotor SS specific Q-ring
    By scyule in forum Singlespeed
    Last Post: 02-08-2013, 08:05 PM
  2. Replies: 1
    Last Post: 10-15-2012, 06:03 PM
  3. Replies: 4
    Last Post: 04-20-2012, 10:10 PM
  4. specific brake rotor bolts?
    By troyer2112 in forum Brake Time
    Last Post: 03-28-2012, 03:44 PM
  5. Clicking sound from new rotor
    By SCR818 in forum Brake Time
    Last Post: 01-22-2011, 09:13 AM
