Results 1 to 3 of 3
    brake rotor replacment help
    Hello I wanted to change my brakes and I notice my rotors dont have torx or allen bolts holding the rotor on but they are like rivets completely flat on both sides. any trick to changing these?
    I have a 07 specialized hardrock sport.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Center Lock rotors don't have bolts
    you need a lockring tool (FR-5)
    Honestly... ahh I give up
    Jul 2003
    Agreed...
    the 07 HR Sport came stock with Shimano M65 centerlock disc hubs. The centerlock system doesn't use torx bolts to affix the rotor to the hub, they use a lock ring as highdell noted. A Park Tool FR5 cassette lock ring tool, or identical tool, will work to remove the lock ring and your rotors. For replacement rotors you'll either have to go with a centerlock rotor, or use a 6 bolt to centerlock adapter if the rotors you want are 6 bolt.
    Good Dirt
