Results 1 to 3 of 3
    Brake Parts Cleaner on Caliper
    Not thinking, I removed my brake pads and sprayed the inside of my dirty Avid Juicy calipers with automotive brake parts cleaner and then wiped them off. Any idea if this would be enough to damage the rubber piston seals inside my caliper? I don't want to risk the brakes going out mid-ride. I assume that when you blow a piston seal, the break loses all power...
    May 2010
    You will be fine. They are rubber seals the brake clean shouldn't eat them. I would use isoprop alcohol in the future put a spray nozzle on it.
    Reputation: supersedona's Avatar
    Dec 2012
    Agreed. The only risk posed with brake cleaner products would be a slight drying of the rubber in the seals, but that is slight. The product is very fast-evaporating so the time on surface is minimal.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
  1. Replies: 0
    Last Post: 06-15-2013, 02:46 PM
  2. Disc Brake Cleaner howling
    By DimitrisCSD in forum Brake Time
    Last Post: 07-18-2012, 08:00 AM
  3. Brake Cleaner for degreaser?
    By powdersurfer98 in forum General Discussion
    Last Post: 09-07-2011, 02:19 PM
  4. did i just eff my brake caliper?
    By CT3 in forum Brake Time
    Last Post: 07-04-2011, 12:53 PM
  5. Auto Brake Parts Cleaner, to clean your bike?
    By ihaveagibsonsg in forum General Discussion
    Last Post: 01-02-2011, 10:55 PM
