Results 1 to 7 of 7
    Mar 2005
    brake pad rubbing rotor, is there a fix?
    Hey guys i just bought an 05 kona stinky. The front brake pad is rubbing on the rotor while i drive, is there a way to adjust this? or do i just wait for it to rub down?
    The brakes are hayes 9. I did try taking the front wheel off then back on but no luck. There is a fair size gap on the other pad and the rotor, i dont see anything to align this.
    Authority is dead!
    Reputation: Lucky13's Avatar
    Quote Originally Posted by cobra
    If one pad is rubbing and another one doesn't, put some washer between the caliper and brake mount of your fork/frame to adjust gaps between pads and rotor. Distance should be the same on both sides obviously.
    For the love of Oi
    Rent a house at Attitash
    Mar 2005
    stupid me
    well i didnt think i was able to adjust the caliper, but a better look at it and i am. I went to hayes website and aligned the pads with cards, works great. thanks
    Authority is dead!
    quite welcome!
    For the love of Oi
    enjoys skidding
    Feb 2005
    i have got the same problem
    except i have a 04 coiler
    i didnt have any problems, but a week later after getting it, the front brake is really dragging. i used the plastic card that came with it to push both the pads back into the calipers, but it still drags a lot.. any ideas? there is such a small margin for adjustment (using a washer), i can't see that being the answer
    enjoys skidding
    Feb 2005
    also, i cant move the pads over any more on the side that it's rubbing on
    should i just let it wear down?
    Sep 2004
    Take the pads out of the caliper. Use a 10 mm box wrench to push the pistons back into the caliper. Be careful not to bend the pad retention stud. Replace the pads.
    Put the wheel back on the bike. Loosen the bolts that hold the caliper onto the mount. Press the front brake lever to center the caliper over the rotor. (Might have to use a few business cards to maintain a little bit of a gap). Tighten the bolts.
    The caliper should be centered in respect to the rotor.
  1. Fix bent Avid Mag brake arm?
    By baumer in forum Weight Weenies
    Last Post: 02-14-2005, 05:52 AM
  2. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  3. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  4. Avid brake pad replacement alternatives?
    By jdcamb in forum Brake Time
    Last Post: 07-03-2004, 10:39 AM
  5. disc brake pad dragging rotor
    By bikeman in forum Tooltime
    Last Post: 06-03-2004, 06:44 AM
