Results 1 to 5 of 5
    XDR
    XDR is offline
    Jul 2013
    Brake Pad/Rotor Contact Area
    Just swapped to some new style SLX/XT brakes with Ice Tech rotors and noticed the brake contact area isn't the same front to rear. The front is a 180mm rotor, with adapter it looks like the pad makes perfect contact, 1mm of gap at the top of rotor and 1mm at the bottom of the contact area. On the rear is a 160mm rotor, it appears that the pad is too far out on the rotor and there is a ~3mm space on bottom of rotor.
    My question is do I shave the post mount on the rear to bring the caliper closer to the center line or is this placement ok? I did a 12 mile test ride today and didn't notice any issues with function. The bike is a Giant Anthem 29er.
    Here is a picture of the front, then a picture of the rear.
    Brake Pad/Rotor Contact Area-null_zpsbf4b6cd9.jpg
    Brake Pad/Rotor Contact Area-null_zps441ad910.jpg
    Biking Like Crazy!
    Reputation: blcman's Avatar
    XDR, is there a IS brake adaptor being used to mount the brakes to the frame. If there is you can grind or file that down to bring the caliper further down.
    Just be careful to make sure you keep things square. If the caliper mounts directly to the frame via post mount, then I wouldn't mess with it.
    2017 Niner Rip 9 RDO Pushed Version!
    2015 Ibis HD3 w/ Push ASC3
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    XDR
    XDR is offline
    Jul 2013
    It is a frame post mount. I just pulled the pads and it looks like the pad is making full contact with the rotor, so no overhang.
    Biking Like Crazy!
    Quote Originally Posted by XDR View Post
    I guess you're good then. Not much I can think of to correct that.
    What brakes were you using before, and how was the pad contact on the rear?
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    XDR
    XDR is offline
    Jul 2013
    It had OE Avid Elixir 5s on it, but those used the conical spacers/hardware whereas Shimanos directly mount. Pad contact on those was perfectly centered.
  1. Shimano AM 45 cleat contact area
    By tangaroo in forum Apparel and Protection
    Last Post: 03-08-2013, 10:33 PM
  2. Replies: 7
    Last Post: 06-08-2012, 06:26 AM
  3. Rotor size/pad contact question...
    By ikarus189 in forum Brake Time
    Last Post: 03-04-2012, 10:58 AM
  4. Taking rear wheel off with 1x9 or 1x10 without rotor v frame contact?
    By danK in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-10-2011, 09:35 PM
  5. Adapter / Rotor contact position question XTR Trail
    By DanielM3 in forum Brake Time
    Last Post: 03-08-2011, 01:10 PM
