    Hatepavement
    Reputation: HatePavement's Avatar
    Brake pad replacement
    I replaced the brake pads on my Superfly 100. Took a bunch of pictures as I was doing it, and added it to our team website as a How-To.
    Rock Racing: Squeal, Grind, Screech
    Holding down the brake lever doesn't always mean the caliper is centered about the rotor. If it works, leave it. If not, manually loosen the caliper bolts just enough to slide them where you want. Then tighten those 2 down!
    Reputation: Lost Biker's Avatar
    cool pics and how-to
    Hatepavement
    Thanks. I did find some rubbing on the rear pads after I took it for a test ride. So I did a second adjustment like egebhardt said, and now they are great.
  1. Disc brake adjustment help!
    By DigitalDJ in forum Beginner's Corner
    Last Post: 01-26-2012, 08:16 PM
  2. New rims, brake drag after first ride.
    By extremedave in forum Brake Time
    Last Post: 01-18-2012, 11:35 AM
  3. Really, really loud rear brake
    By Eazy_E in forum Arizona
    Last Post: 01-16-2012, 12:14 PM
  4. Brake Q's?
    By RaindogT in forum Urban/DJ/Park
    Last Post: 01-15-2012, 10:18 AM
  5. Brake Lever Question
    By JCP281 in forum Beginner's Corner
    Last Post: 01-12-2012, 05:38 PM
