Results 1 to 6 of 6
    No longer 26
    Reputation: G-Live's Avatar
    New question here. Brake Levers for Avid Mechs and Sram Twist Shifters?
    Have been using Avid Levers for my Avid Mechs and they work great. However, I am an badfinger braker and find I have to shift my hands a bit uncomfortably to use the levers. Are there any longer levered levers out there that are reasonable weight for use on a XC bike? Do SRAM 9.0's work well with Avid Mechs?
    Greg
    Reputation: mtbykr's Avatar
    avid
    i use sram xo shifters, avid mech brakes and avid speed dial 7 levers. the xo have a shorter shifter surface, so the levers work great. i also use yeti harcore 3/4 lock on grips. this is the best set up i have found to date
    hope this helps
    The nine most terrifying words in the English language are, 'I'm from the government and I'm here to help.' --Ronald Reagan
    check yer PMs...
    Reputation: Rollin'in'Zona's Avatar
    Both my girlfriend and I have SRAM x9 twisties w/ Avid SD7 on our trail bikes. Work fine!
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    Paul 2.5's
    Quote Originally Posted by G-Live
    Greg
    Here's what you're looking for (on sale too):
    http://www.webcyclery.com/product.ph...cat=276&page=1
    http://www.paulcomp.com/
    formerly Giantxc
    Reputation: MrXC's Avatar
    I was in the same boat up until about a year ago. What you want to look for is the Avid SD 2.0L. With this lever avid offset the pivot 5-10mm so the tip of the paddle is a little further out. The only catch is they don't make them any more. I bought a set either off of MTBR or Ebay. I've also heard that the original Avid Ultimate lever for v-brakes was wider but have not confirmed.
    Also I'd avoid the SRAM 9.0 levers like the plague. They're plenty long for use with gripshifts, but the paddles flex like a wet noodle. I bought my first set of avid levers because of the fear those levers instilled in me during a long, steep downhill.
    Greg
