    Flying Goat
    Reputation: mrpercussive's Avatar
    Brake Lever will not return to original position...
    I've got a set of Hayes HFX9 HD Masters and the lever wont return to it's original position. It's stuck somewhere in between. You can press it and it'll return to the center... not all out to where it supposed to be... any ideas on what i should check for?
    Race Technician
    Reputation: Randy@Hayes's Avatar
    Jan 2005
    A little.....
    too much loctite on the adjuster bushing threads of the pushrod? It usually works its way to the outer diameter of the adjuster bushing and prevents the lever form returning. Give us a call on Monday and we'll send you some of the new bushings. 1-888-MTN-DISC
    Randy
    Flying Goat
    sweet... thanx Randy... will give you guys a call monday... you just gave me a lot of confidence in hayes...
    Flying Goat
    found the problem after tinkering with it a little... the lever adjuster with the hex wrench... thanx for offering to replace the bushings though...
    now just need to bleed the brakes...
