Results 1 to 3 of 3
    brake fluid on pads
    I think that when i was bleeding the brakes i got some brake fluid on the pads, now they are howling. I sanded them down, however they still make a racket. Any ideas, or should i just replace the pads? Thanks!
    Former Bike Wrench
    You need to cook them...I hold the pads with some pliers and use a small propane torch to heat up the back plates. You'll see smoke as the contaminates burn off, once the smoke stops (just a few seconds) then stop. This can often salvage your pads.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    don't forget to clean the rotors too
    Honestly... ahh I give up
