Results 1 to 3 of 3
    Oct 2003
    Brake Fluid Damage
    I'm upgrading to disc brakes and am considering buying a used set of Hayes HFX Mags. They've had minimal use and seem to be in good condition except for some paint damage on one lever from brake fluid. Is it normal for brake fluid to leak and cause this type of damage on hydros? Does this indicate some sort of problem with the brakes? Thanks.
    Reputation: Slack's Avatar
    Quote Originally Posted by ErikO995
    Is it normal? Well, no.
    Is it common when people bleed their brakes? Yes.
    Ask the seller what the deal is. Ask for a further discount because of the damage and risk you're taking. Hayes' are easy to rebuild... worse case.
    Reputation: toad's Avatar
    Yes, all too common
    Hayes brake levers have some seriously bad paint on the levers. It flaked off on mine just from tightening down the lever on the handlebar. Don't fret over a little missing paint. Hayes commonly have that problem. -t
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. alternative for shimano brake fluid
    By ttown in forum Brake Time
    Last Post: 06-28-2004, 07:22 AM
  3. Rear V brake adjustment with ENO hub?
    By jh_on_the_cape in forum Singlespeed
    Last Post: 06-08-2004, 01:24 PM
  4. Hydro fluid - only use from new, unopened bottle
    By frank n. beans in forum Brake Time
    Last Post: 04-05-2004, 10:04 PM
  5. Marta SL bleeding - what am I doing wrong?
    By AnoBlur in forum Brake Time
    Last Post: 03-28-2004, 06:52 PM
