Results 1 to 10 of 10
Thread: brake fluid
    brake fluid
    Can I use any Dot 3 or Dot 4 brake fluid or does it need to be for small brake systems?
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    Quote Originally Posted by mlepito
    If your brakes use DOT fluid, yes you can use any Dot 3 or Dot 4. I'd use Dot 4 since it's not much more expensive.
    I'm also having a hard time retracting the pistons. Even with the reservoir cover removed they won't stay all the way retracted for me to put the new pads in.
    Jun 2005
    Might help if you posted what brakes you have.
    Typically pads have a hard time retracting if the system is overfilled. But you say you have resovior cover off, so that may not be it.
    In another thread you say you have XT brakes. Shimano uses mineral oil and NOT DOT brake fluid. Don't mix the two different types.
    Get mineral fluid made for brake systems and not the stuff at the drug store.
    This is on a friend's bike. He has Quad brakes. I took the cover off and pushed the pistons in which of course made fluid spray out, but then they push back out. They won't stay in.
    If they move back out on their own, I'm guessing there is air in the system. It would compress the air when you press the pistons back.
    That would make sense. When I pulled the cover off the reservoir was only like half full. I'll bleed them and then try to retract them. God, why is something that should be so simple such a pain in the ass?
    ...God, why is something that should be so simple such a pain in the ass?
    It's because you're trying to help a friend.......no good deed goes unpunished.
    Well at least if I break it (which I already did) its not mine.
