Results 1 to 5 of 5
Thread: Brake Fad
    Brake Fad
    Alright, I am 5'10" 225#. for the last year I have been riding a giant trance with juicy 5s 180mm front rotor and 160 rear. I am running dot 4 in the front and 5.1 in the rear(I ran out of 4 and had to go buy 5.1) Last year I put on a set of disco brake pads that I bought on ebay. they are semi metallic on front and back. Today I was on a steep section of trail and they absolutely faded out. I had both brakes locked and it was like I they were not there. Font rotor was purple. I have ridden two xc races on these and did a day at whistler last year with no problems!( I bled the brakes right before whistler)
    Does anyone have any ideas on what I could do to prevent this from happening again. I am wondering if rode the brake too much however the fact that this did not happen at whistler has me wondering. I am going to re bleed but was wondering if maybe ceramic pads may help. Has anyone tried them? Does it sound like my brakes are under spec?
    Reputation: vk45de's Avatar
    If your lever feels solid then it's just pad fade. You can go for bigger rotor and/or high temp pads such a sintered metallic. I've read that ceramic pads are better than semi-mets for extreme applications but I haven't tried to cook them in the same setup yet so I can't say.
    Weekend Warrior
    Reputation: daleksic's Avatar
    Even at 225# the brakes should work just fine. I would flush out the brakes. AVID says that the Juicy 5 & 7 require Dot 5.1 fluid only; the Juicy 3 uses Dot 4.
    Also make sure they are bleed correctly, it sound you might just have an air bubble somewhere in the line. I experienced brake fade similar to what you experience with my car once. As soon as the temp goes up the brake power disappears.
    Meh.
    Reputation: XSL_WiLL's Avatar
    The J5 and J7 can use DOT 4 or 5.1. There are DOT 4s with higher boiling points than DOT 5.1 (Motul RBF600).
    Even though the lever is firm, the fluid may be old and absorbed a lot of moisture. This would lower the boiling point.
    I think I need to Upgrade
    Reputation: AzSpeedfreek's Avatar
    Quote Originally Posted by mtiny83
    It may be time for a fluid flush. How worn down are the pads? The more they wear down the less ability they have to shed or release heat. Your rotors are probably glazed now also. I would replace pads, fluid and sand the braking surface down on the rotors.
