Results 1 to 7 of 7
    monster member
    Reputation: Wheelspeed's Avatar
    Brake Drag After Wheel Removal
    Anyone ever have to readjust the caliper every time they remove and reinstall a wheel, like to fix a flat?
    All I can think of is that the teeth at the ends of the caps of the hub dig into the aluminum of the frame differently. It's a recently built bike with new hubs, so I guess they're still digging into the aluminum. I re-set the caliper perfectly, which takes some care with these Avid Elixir CR brakes, and then the first flat I get leaves me with a dragging brake for the rest of the ride... front or back. (Aluminum drop-outs on both ends.)
    I'm sick of it! Does it go away after awhile? As the drop-outs get more chewed up by the hub ends, will the problem go away? Or, should I use some kind of washer?
    Have fun!
    You could be adjusting the QR differently every time.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Wheelspeed
    Get some QuickNuts
    mtbtires.com
    Keep weight on the tire as you tighten the QR to be sure the axle stays bottomed out in the drop-outs.
    monster member
    Forgot to mention I'm using a bolt-on axle since noticing the cheap QR that came with the wheel tried to move the axle a bit as I cinched it down.
    Yep, keeping weight on the wheel.
    Adjustment of the QR or bolt-on doesn't change the width of the hub.
    Have fun!
    I'm just messing with you
    Reputation: wv_bob's Avatar
    I was skeptical too, until I proved it to myself. I use a QR, and loosening a 1/4 turn, or tightening a 1/4 turn would change how much (or if) the brakes would rub. Not sure how you could repeat that experiment with a bolt-on hub though.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Yep that's what it probably is.....
    I do not notice the issue with the 15QR on my new bike, because the nut the axle threads into stays in the fork in the same spot, so it is tightened exactly the same each time....
    brake stays lined up.
