    New question here. Brake Compatability
    Hi All,
    Thanks in advance for your help! I have a stock 1996 Cannondale M500 which I just pulled out of the attic at my mother's house. Although covered in dust, the bike is in new condition. I cleaned and lubed it but I noticed I have a broken back brake caliper. By broken I mean the pad is missing and the part of the caliper that holds the pad post is missing the hardware to hold it in place. The original brakes are Shimano Alivio M-System Brakes. In searching for a replacement, I found that V-brakes are now the standard. What type of NEW calipers should I purchase? Will V-Brakes work on my Cannondale frame brake mounts? Is it still possible to purchase Alivio M-system brakes now that some 13 years have passed? I'll accept any working substitute but dont want to dump a boatload of cash either. Once again thanks for your help. Happy riding.
    Old man on a bike
    While the direct pull (v-brake) calipers will fit on the brake posts on the bike, they don't use the same amount of lever pull as your cantilever calipers, try reading this http://www.sheldonbrown.com/canti-direct.html
    suum quique
    Live 2 Ride
    Reputation: Kona0197's Avatar
    So he would have to buy new brake levers as well.
    My Bike: '15 Trek FX 7.2
    My Blog: http://http://kona0197.wordpress.com/
    Reputation: logbiter's Avatar
    sounds like all you need is a new set of brake pads, which you should replace anyway, since they're likely rock hard after sitting for years in a hot attic.
    v-brakes are compatible, but would require new brake levers. Grab some kool stop cantilever brake pads and you'll be good to go.
    here's a website to look at for repairs. http://www.parktool.com/repair/readhowto.asp?id=19
