Results 1 to 19 of 19
Thread: Brake cleaner
    Jason
    Reputation: dexetr30's Avatar
    New question here. Brake cleaner
    Can I use automotive brake cleaner to clean my XT hydro pads and rotors?
    Jason
    ____________________________________________
    The bicycle; the noble invention that saves my health, inside...and out.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Quote Originally Posted by dexetr30
    I wouldn't - ISO alcohol is fine and muuuuch cheaper
    I recall people sayin that it has some residue (brake cleaner that is)
    Honestly... ahh I give up
    A lot of these 'cleaners' make problems worse. If you need something for the pads then try using a wide and flat knife sharpening stone. With the pads out you can rub each one up a down a few times to get a brand new surface. Removes any glazing into the bargain.
    Former Bike Wrench
    Stick with Isopropyl Alcohol...cheap, evaporates quickly, and leaves no residue (and pretty harmless environmentally as well).
    Reputation: mullen119's Avatar
    I tried brake cleaner on my bb7's a few years ago and it messed them up. Use alcohol on the rotor and lightly sand the pads to rough them up. Then wipe the dust of the pads and you will be good to go.
    Reputation: Dex11's Avatar
    May 2005
    I use Isopropyl Alcohol too, works great !
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Have been using BelRay brake & contact cleaner for many years with no problems. A inexpensive way to deglaze pads is sanding in a figure 8 on cement.
    Formotion Products
    http://www.formot
    Jason
    Thanks for all the replies. Isopropyl alcohol it is!
    Jason
    ~Disc~Golf~
    also, when you shop at the drug store (or whatever) there are two different types (formulations); a 'regular' ISO at 70%* and a 'rubbing' at 91%*.
    70% is gonna be a bit more gentle for cuts, but 91% will be better for cleaning
    *=mental recollection may be off
    Old man on a bike
    Better than the drugstore, go to the hardware store and get denatured alcohol.
    suum quique
    Jason
    Highdell, I usually only buy 91% even for my own personal use. It hurts like hell but gets the job done.
    Bikingfool, I've used denatured for other things and I've seen it leave a white-ish residue. Is this going to be a problem?
    Jason
    ~Disc~Golf~
    Denatured alcohol is ethanol with additives (like gasoline and other stuff) to make it unsuitable (poisonous) for drinking.
    While ISO is Isopropanol with water added.
    I'd stick with the isopropyl, but that's just me - seems to work for bikinfool (whose opinion I usually trust)
    Old man on a bike
    I forget who/where I picked up the recommendation, think it was somewhere here in these forums but quite a while back. There are different formulations, but it should be a higher alcohol content and not watered down, although it may have other additives. It's worked well for me, haven't noticed any residue. Plus it makes a handy fuel for the camp stove if needed!
    You got me wondering a bit and found this bikeforums.net thread discussing the various possibilities of denatured alcohol and cautions for handling it. http://www.bikeforums.net/archive/in.../t-120724.html. Next is to go find an MSDS for the brand I bought....
    suum quique
    Jan 2005
    Quote Originally Posted by Bikinfoolferlife
    You really dont want to know what your working with, It'll make you want to jump off a cliff. Especially dont check the MSDS of the food you eat and what its cooked in/with.
    Formotion Products
    http://www.formot
    Jason
    I have a bottle of 70% in the shop right now. Should I use cotton balls to apply or just spray on with a spray bottle and let evaporate? When the 70% is all gone I'll order a few bottles of this stuff.
    Jason
    Old man on a bike
    It wasn't too scary, apparently just rebranded Klean Strip in any case. Guess that old adage that there's really only a few factories overall applies here, too. Only methanol, ethanol and a bit of methyl isobutyl ketone in it...
    suum quique
    Jan 2005
    Shop towels.
    Formotion Products
    http://www.formot
    I have a bottle of 70% in the shop right now. Should I use cotton balls to apply or just spray on with a spray bottle and let evaporate?...
    If you spray it on and let it evaporate, it won't remove anything. Use the alcohol on a rag or paper towel and wipe the rotor.
    Jan 2005
    Just warm it like Saki it goes down smooth.
    Formotion Products
    http://www.formot
Members who have read this thread: 12
