Results 1 to 15 of 15
Thread: Brake Choices
    Brake Choices
    I work at one of my LBS and I am going to buy new brakes. Currently my Trek 2009 6700 came with Avid Juicy 3's. I want a very powerful brake, I used to be able to do endo's on my bikes with v-brakes but with Juicy 3's I can not. So I want something that will give me the power to do so and still work with the 2009 Trek 6700. The following companies I can order from and get employee purchase from:
    Avid
    Shimano
    Hayes
    Hope
    Formula
    Magura
    Any suggestions?
    2009 Trek 6700D
    ...idios...
    Reputation: SteveUK's Avatar
    Type of riding? Bike (and fork)? How much do you weigh? Can nobody in the shop you're somehow employed give you a clue?
    Diogenes
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    The last three on your list, all have the power you are asking for. I'd go with the Magura Marta SL, if you ride XC- or lots of trails. The Maguras stop with tons of modulation, power, and don't require corrosive DoT 4 brake fluid, like the others do. Employee discounts always help!
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Everyone I work with has their own idea to the best brakes, so I thought I would post.
    I ride mostly singletrack/ XC. I am 6"1' and weigh 160lbs. The fork on my bike is a RockShox Recon SL 100mm. I might eventually upgrade but not now.
    Other specs:http://www.trekbikes.com/us/en/bikes...6_series/6700/
    And I would like something that I can put Goodridge brake lines on.
    2009 Trek 6700D
    Jul 2003
    How long and how many rides....
    do you have on the bike? Might be a simple matter of beak in, i.e. bedding in the pads to the rotor. Most disc brakes do require a break in period before you'll see peak braking performance. Usually around 5 or 10 rides depending on the length of the rides. It also might be a simple matter of going one rotor size up on the front. Your bike comes speced with 160mm front and rear. Most riders will usually go one up on the front to increase the power of the front brake. You usually don't need the extra in the rear. Going one rotor size up tends to equalize the brakes better, i.e. for a given lever pull the rear is less likely to lock up, and you have the extra power where you need it. So it may be as easy as going to a 185mm rotor up front.
    Your call, if you really want to upgrade the brakes then go for it. But I'd try the 185mm front rotor first. You might be surprised.
    Good Dirt
    Since I still know nothing about the OP, I will recommend those Taiwanese hydraulics I know nothing about as well. I don't hear anything good or bad about them, so they might fit the OP's needs...or not, I don't know.
    I had the J3's on my EX7, ended up putting a 203 on the front to get any power out of them but still blew some turns that I should have been able to make. Just upgraded to K24's w/ 160's. Better modulation and power than the J3's. Took longer to break in but worth the wait.
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    Chicks dig Formulas I have found
    Where did you find them?
    Quote Originally Posted by Jerk_Chicken
    at the intersection of hollywood and vine
    Quote Originally Posted by Squash
    Good Dirt
    I have had the bike for 3 months with about 400 miles on it. I never thought of just trying a bigger rotor in the front.
    2009 Trek 6700D
    I have been thinking about Magura Gustav, is that a nice brake with lots of stopping power.
    2009 Trek 6700D
    Dec 2008
    I guess there's something wrong on your brakes. May be contaminated pads or something.
    But if you can't even do an endo, they are not working right. Have them checked by your LBS before buying new ones.
    ...idios...
    "I have been thinking about Magura Gustav, is that a nice brake with lots of stopping power."
    Are you for real?
    Diogenes
    Are you for real?
    Is that one of the best I can get? I have heard it has lots of stopping power but I am only familiar with Avid and Shimano products.
    2009 Trek 6700D
