    m_c
    m_c is offline
    Mar 2005
    New question here. Brake Boss Hose Guides
    Is there such thing as imperial threaded versions off Hope Hose Guides?
    I've got a Black Sheep Titanium softtail frame, that I'm wanting to start building up, and am looking for some hose guides that will screw into the brake bosses. I've already bought some 10mm Hope hose guides, but I didn't think about the fact that as the frame is american, it'll use imperial threads (3/8 UNC in this case). So I had a D'oh moment when I realised they wouldn't screw in.
    My searches so far haven't found anything similar with a 3/8UNC, so I'm hoping people on here might know.
    Reputation: lebikerboy's Avatar
    Jan 2005
    Metric sizing is standard in the bike industry. I'd recheck the sizing.
    Quote Originally Posted by m_c
    Don't touch me!
    Reputation: beeristasty's Avatar
    Edit: Jebus I need to try reading more thoroughly.
    Assuming you've taken off the canti studs and they don't fit, I'd check to see if they are the 8mm fork models. If they are, you'll (of course) need the 10mm frame model. Like said earlier, bikes are metric.
    This may irk you though, some people have said they don't fit very well when installed. This is due to the fact that the threading for all frames and forks are probably not uniform; or more like not universally the same. So there will be variance between everything. I would expect the worst and hope for the best.
    No offense to KB, but if I see another "Strong, light, cheap. Pick two" line on this site...
    MCM# eleventy billion
    No offense to thieves, but if I see another "Ride it like you stole it" line on this site...
    m_c
    m_c is offline
    Mar 2005
    I finally remembered to take the canti mount into the workshop and check it, and it is definately a 3/8UNC thread. However, while building the frame up today, I realised that there's a hose guide on the front side off the seat stay, so the brake boss hose guide isn't required. I'll just find a couple gromits to blank the brake bosses, to stop the threads getting full of dirt.
    moray
  1. Brake hose boss for Intense Spider
    By gr8spinner in forum General Discussion
    Last Post: 02-23-2005, 09:07 AM
  2. Replies: 4
    Last Post: 02-18-2005, 05:58 PM
  3. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  4. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  5. Broken brake boss question
    By Locoman in forum Shocks and Suspension
    Last Post: 06-22-2004, 07:42 PM
